 Post subject: HDD Low Level Format Tool
PostPosted: June 9th, 2010, 15:59
Hi, I just used the HDD Low Level Format Tool, and my hard drive (seagate 500gb), can't be seen on windows. I mean that its like is no there but I get the sound when I plug it in. What can I do??
 Post subject: Re: HDD Low Level Format Tool
PostPosted: June 9th, 2010, 16:43
Format it.
www.datarecoveryne.com
PostPosted: June 10th, 2010, 6:58
Use Disk Management to partition it, then format it.
How to use Disk Management to configure basic disks in Windows XP:
http://support.microsoft.com/kb/309000
The Low Level Format Tool writes zeros to every sector on the drive. A format at OS level is a "high" level format. It creates a file system on the specified partition.
PostPosted: June 10th, 2010, 7:02
Sounds like FW corruption or ATA password.
PostPosted: June 10th, 2010, 8:12
Seen by BIOS at POST = half way. Not seen ? Firmware problem , hardware failure, cabling problem , something else.
