 Post subject: Need help with detecting that PCB
PostPosted: June 8th, 2010, 18:13
Hi All,
I have that HD:
http://img710.imageshack.us/i/dsc03969t.jpg/
With that PCB:
http://img690.imageshack.us/i/dsc03970t.jpg/
http://img52.imageshack.us/i/dsc03973u.jpg/
I suspect that the PCB is burnt.
I found this alternative PCB.
http://www.softcom.com.my/wd2500ks.htm
Is it good for me? or I need the BIOS chip replacement?
Best Regards,
 Post subject: Re: Need help with detecting that PCB
PostPosted: June 8th, 2010, 18:20
You will need to transfer ROM
Data Recovery Ireland
PostPosted: June 8th, 2010, 18:29
O.K, but beside of that, that PCB will be in a high probability a good match?
PostPosted: June 9th, 2010, 18:15
somebody?
PostPosted: June 9th, 2010, 18:21
dude, you can't be spoon-fed all your life here. There are lots and lots of posts about this. Use the search function. The only way you will learn is to experiment (not with customer drives!!).
PostPosted: June 9th, 2010, 18:23
you will have to rebuild the rom from the sa.
Easy like this.
ZeBong
" Россия еще раз"
PostPosted: June 10th, 2010, 6:58
By people's answer I'm study and know new things
Users browsing this forum: Google [Bot] and 123 guests
