 Post subject: Breaked 7200.11 fix procedure
PostPosted: June 16th, 2010, 9:47
Hello
Can anybody help
What to do, when was interupted the m0,2,2,,,,,22 procedure
on Seagate 7200.11?
It was powered off the drive in 1 second after start m0 command.
Now is not possible to get F3 T>
THANKS for soon reply
 Post subject: Re: Breaked 7200.11 fix procedure
PostPosted: June 16th, 2010, 14:04
What tools are you using on this one? Were you sure before doing this that the drive had this error. ACE now has a new script in the program for this problem should follow it if the drive has the standard busy problem. If not you do not have toold this could be a problem and maybe you have bricked your drive.
Iorana Haraharaini
PostPosted: June 16th, 2010, 15:27
Ann , the problem is that power was cut during m0 command...
PostPosted: June 16th, 2010, 19:15
ddd123 wrote:
Hello
Can anybody help
on Seagate 7200.11?
Send it to Seagate / i365. Their data recovery service will probably be free, or would have been free had the drive been received in its original state.
Worth a try, anyway.
PostPosted: June 16th, 2010, 19:28
have you try conntact PCB only and check?
data recovery service[/b]
Users browsing this forum: Google [Bot] and 88 guests
