 Post subject: seagate st3500320as 500gb
PostPosted: June 22nd, 2010, 11:53
Hard drive was working find when I shut it down last night. Came in this morning and hard drive not found in bios. The drive is spinning up just not being recognized. Will take it home and take off the pcb board and check to see if anything is out of the ordinary. Any other suspects beside the tvs? Thanks.
 Post subject: Re: seagate st3500320as 500gb
PostPosted: June 22nd, 2010, 11:54
TVS is not bad, if TVS was bad disk would not spin
I suspect you are victim to common SA failure, this disk is part of 7200.11 series.
PostPosted: June 22nd, 2010, 12:19
Here are the specs
S/N 9qm69n1t
St3500320as
p/n: 9bx154-335
Firmware: sd15
Date code: 09085
PostPosted: June 22nd, 2010, 12:39
It looks like I may have been affected by the firmware issue that kills the drive. I will be seeing if seagate will fix it for free or try fixing it myself using this link
http://www.overclock.net/hard-drives-st ... -pics.html
PostPosted: June 22nd, 2010, 13:19
Most likely FW problem. If you have an important data just send it to a pro.
OR search this forum for the "busy" problem and do it on your own risk.
Good luck.
Users browsing this forum: No registered users and 262 guests
