WD1600AAJB H.D.D NOT DETECTING IN BIOS
June 18th, 2010, 9:37
Hello.
My WD1600AAJB suddenly fail.
Disk spin up, but not detecting by BIOS. No noise or visual damage on PCB.
I bought a new similar disk and swap PCB. No luck.
I looking for the U12 chip, but can not see it.
Patient disk:
WD1600AAJB-00J3A0
Date: 02 apr 2009
DCM: DGRNHTJAGN
PCB: 2060-701596-001 REV P1
Donner disk:
WD1600AAJB-56R1A0
Date: 16 feb 2010
DCM: HHRNNT2AHN
On Ebay it is an other PCB for sale, is this a better choise?
WD1600AAJB-00J3A0
DATE: 06 FEB 2009
DCM: HGRNHTJAHN
2060-701596-001 rev P1 on the PCB
So, what to do?
Picture on patient PCB.
Re: WD1600AAJB H.D.D NOT DETECTING IN BIOS
June 18th, 2010, 10:04
This board does not have an external flash chip. It has a masked ROM within the CPU- the large chip on the board marked with an M. If the PCB is the problem- which it may not be- you will need a professional to copy the contents of the ROM from the patient to the donor. Although you would- like everyone else on this forum -like to do this yourself, I'm afraid unless you invest substantial money in the necessary professional tools this is not possible. Moreover, the PCB is not necessarily the cause of the problem so you'd still need to find a professional DR service if your data is critical.
June 18th, 2010, 10:27
msurgeon wrote:Moreover, the PCB is not necessarily the cause of the problem
If the PCB is OK, why does it not shown up in BIOS?
June 18th, 2010, 10:37
Because something else is wrong with it
June 18th, 2010, 10:39
There are many reasons other than PCB failure that a drive will not show in BIOS. Among them are: head(s) failure, firmware damage, platter surface damage, or any combination of these. In fact, PCB failure is usually the cause - in our experience- about 10% of the time.
June 18th, 2010, 10:56
Ok. Thanks.
How do we detect the failing part?
June 18th, 2010, 11:03
soren60 wrote:Ok. Thanks.
I'm afraid that you can't. This can only be diagnosed properly by a data recovery professional. Many companies and individuals advertise themselves as "professionals" but have no idea what they're doing when it comes to physically damaged drives. Research companies in your area who do DR and see if you can get some good referrals. It's easy to screw up these drives permanently in the wrong hands. I don't recall any pros on this forum from Sweden but you can check.
June 18th, 2010, 11:16
Diagnosis is easy. Send to a data recovery professional who provides a free assessment. You will find out the problem and the cost to recover the data.
June 18th, 2010, 11:24
mr_spokk is from sweden.
Dobre
June 18th, 2010, 14:21
Ok.
But if problem is located to PCB, what can I do? Swap the M-chip?
June 18th, 2010, 18:02
soren60 wrote:Ok.
Contact http://www.onepcbsolution.com/.
They offer a ROM transfer service for $10. I don't know whether that covers your model, though.
June 18th, 2010, 19:55
since there is no ROM, neither place for it on that pcb, the drive will need professional attention.
it is not about swapping ICs. If u would like to see your data again I suggest stopping DIY attempts before it will be late.
June 18th, 2010, 21:00
pepe wrote:since there is no ROM, neither place for it on that pcb, the drive will need professional attention.
I have no idea as to the professional standing of http://www.onepcbsolution.com/.
However, when a vendor offers a ROM transfer service, this does not necessarily imply that the service is restricted to physical chip transfers.
June 18th, 2010, 22:50
It's probably a firmware problem - e.g. module 11 is corrupted. If so, there is nothing you can do yourself.
June 19th, 2010, 19:06
Now I did a test with MHDD 4.6floppy.
MHDD did not recognize disk.
I did two different tests.
Test1:
Boot computer with electric power off/on.
Disk spin up, and MHDD highlight BUSY, after 10sec disk stopped an highlight ERR.
Test2:
Boot computer soft.
Disk spin up, and MHDD highlight DRSC and DRDY, disk do not stop.
June 19th, 2010, 19:34
soren60 wrote:Now I did a test with MHDD 4.6floppy.
Test1:
Test2:
Boot computer soft.
without proper PCB your test nothing meaning. i can help you transfer ROM data into good PCB. please contact me by email or MSN if interesting. swap the MCU chip is the way. but do you think you will get success on swap it? ******think over and over before action*******
June 19th, 2010, 19:44
Hi, if you value your info on your harddrive don't play around with it to much...otherwise you can lose it all!
A failing drive is not going to be better by trying accessing it with the wrong tools all the time!
Regards/ Bosse
June 19th, 2010, 19:52
networkpc3000 wrote:without proper PCB your test nothing meaning. i can help you transfer ROM data into good PCB. please contact me by email or MSN if interesting. swap the MCU chip is the way. but do you think you will get success on swap it? ******think over and over before action*******
Ok, you are sure that PCB is the problem?
When you transfer ROM data into good PCB, do you "flash" the new MCU, or do you swap MCU physical?
And yes I am intressting of your help, if it is for a resonably price.
Where do you live networkpc3000?
June 20th, 2010, 1:03
soren60 wrote:When you transfer ROM data into good PCB, do you "flash" the new MCU, or do you swap MCU physical?
Depending on your soldering skill and on the MCU condition.
June 21st, 2010, 3:55
i always "flash" original FW into new MCU(good PCB), instand of swap MCU physical. it more easy and safe to do it.
