 Post subject: WESTERN DIGITAL H.D.D LOOKS DEAD
PostPosted: June 28th, 2010, 8:32
WESTERN DIGITAL 40 SATA H.D.D
S/N:WMAMA3449103
WD CAVIAR SE
LBA 78165360
MDL: WD400JD-22NCO
DATE: 28 APR 2005
DCM: ESCHCVJAH
STARTED THE SYSTEM AND CMOS DIDN'T FIND THE H.D.D. OPENED THE H.D.D AND FOUND THAT THE SMOOTH IC WAS BURNT. REPLACED WITH SAME ONE BUT THERE IS NO SPIN UP. PLZ HELP
http://tinypic.com/m/apfq8g/1
http://tinypic.com/m/apfqdc/1
http://tinypic.com/m/apfqeu/1
 Post subject: Re: WESTERN DIGITAL H.D.D LOOKS DEAD
PostPosted: June 29th, 2010, 5:13
Do you mean that you replaced the SMOOTH chip?
PostPosted: June 29th, 2010, 7:38
There's probably a lot more dead than the smooth. Smooth makes negative powersupply also.
If it blows, its very likely some other components die with it too.
You'll need at least to replace the whole pcb and then transfer the rom contents.
If then it clicks, heads are dead too and its the end of DIY.
Dobre
Murphy was an optimist
PostPosted: June 29th, 2010, 7:54
Oh no it's not the end... where common sense ends, mcgyvering begins.
PostPosted: June 29th, 2010, 8:06
Why not rebuild rom from SA? Hey its worth a shot right? Any idiot can do that for sure. :)
Zero Alpha: zeroalpha.com.au
PostPosted: June 29th, 2010, 8:44
An idiot with 10'000 $ worth of gear to do it ...
PostPosted: June 29th, 2010, 8:52
Yes replaced it with same ic type
PostPosted: June 29th, 2010, 8:54
Dobre
give me some ideas on how to test the other components
PostPosted: June 29th, 2010, 8:56
Whats SA?
Logic boards are costly (Rs. 1700). With that price I can buy a new hdd. Plz provide some repair tips.
PostPosted: June 29th, 2010, 9:25
Buy a new drive.
PostPosted: June 29th, 2010, 9:57
SA = Service Area
guys give the man here a break
using pc3k
PostPosted: June 29th, 2010, 11:16
He doesn't have PC3k nor anything else except hyperterminal :(
PostPosted: June 29th, 2010, 20:21
You can get new drives for less than $50 so why waste time trying to repair a dead drive?
PostPosted: June 30th, 2010, 19:37
Dobre
Can you upload a detailed photo? I can't make out anything in your other photos.
BTW, what are the part numbers on the two SMOOTH chips?
Users browsing this forum: Bing [Bot] and 71 guests
