 Post subject: WD400BB-00CAA0 problem
PostPosted: June 29th, 2010, 2:04
Hi guys
Drive is clicking continuosly and then safemode, pcb ok. I tried head exchange so far i have no luck, may be due to alignment or incompatible preamp. I put all the donor's head back to the original HDD and it works, so i guess alignment issue is ruled out. Single platter drive, surface ok.
So far i have tried 4 donors without any luck. Any help much appreciated.
 Post subject: Re: WD400BB-00CAA0 problem
PostPosted: June 29th, 2010, 3:01
So drive has 2 heads and you can't get SA with either of them?
Zero Alpha: zeroalpha.com.au
PostPosted: June 29th, 2010, 3:05
no, the drive not even calibrated.
PostPosted: June 29th, 2010, 12:49
Are you waiting for the drive to allow SA access, or are you gently persuading it to do so? :wink:
Have you got another working drive of the same family?
PostPosted: June 29th, 2010, 20:23
Did you do a good test of the pcb? This should always be done first before opening.
PostPosted: June 30th, 2010, 12:35
Indeed, What have you done to insure the PCB is "ok"
I have seen plenty of WD where the PCB may seem ok at first, but maybe R/W Channel or MCU is having problems, corrupting data being read by the heads, causing the same clicking effect.
Users browsing this forum: No registered users and 144 guests
