 Post subject: ST3200350AS SD04 Firmware require
PostPosted: July 1st, 2010, 3:20
I need this firmware, If anyone had please upload or give the link.
thanks
regards
RAID/Server Recovery
 Post subject: Re: ST3200350AS SD04 Firmware require
PostPosted: July 1st, 2010, 8:48
Why do you need the firmware?
PostPosted: July 1st, 2010, 8:58
the original sd04 firmware was flashed by sd1a wrongly...
PostPosted: July 1st, 2010, 9:05
I dont have SD04 fw on any resources :(
but if you are going to be modifying SA info, you really need to take care. Replacement of wrong information can render disk unuseable.
PostPosted: July 1st, 2010, 9:14
any other compatible fw which you suggest to replace in case I did't find sd04 ?
PostPosted: July 1st, 2010, 9:46
Sorry, I am not so sure. If you want to rewrite SA I would make tests on donor disks first.
I am not so sure that FW can be reversed because ROM is also modified, and this can not be modified under commercial tools (I assume you have PC3K or SD????)
PostPosted: July 1st, 2010, 12:24
ok, i have 1 more questions
can i restore the default setting through terminal, just like we deal with busy bug issue of 7200.11, it is the same family ?
Users browsing this forum: Google [Bot], nicola and 97 guests
