 Post subject: wd royl selfscan
PostPosted: July 1st, 2010, 10:40
WD royl selfscan, use MHDD test, there are dozens of green blocks of color <150ms, have any good way to deal with it?
 Post subject: Re: wd royl selfscan
PostPosted: July 1st, 2010, 14:11
Selfscan with MHDD? Omg, Dmitry, since when? :mrgreen:
PostPosted: July 2nd, 2010, 1:47
You can always write scripts to start selfscan with mhdd :wink:
PostPosted: July 2nd, 2010, 2:26
I know you know that we know... :mrgreen: in this case most probably the term 'selfscan' was misunderstood.
PostPosted: July 2nd, 2010, 8:31
he probably means surface scan "F4" right?
Zero Alpha: zeroalpha.com.au
PostPosted: July 2nd, 2010, 8:56
I think he/she knows what he/she is talking about.
Anyways, the way I read the questions is that after a selfscan the drive was checked with Mhdd and has allot of sectors with <150ms, the operator want's to know if there is anything that can be done to get faster reads on those sectors. I am not a selfscan guy, so I can not help :cry:
BlackST, Rameez, seams that the OP requires your type of expertise and deeper knowledge of SS here.
PostPosted: July 2nd, 2010, 12:36
quasimodo:You understand correctly! WD royl selfscan normal completion!With mhdd test, there are dozens or more of the green block with <150ms, Who have
a better approach?
PostPosted: July 2nd, 2010, 13:57
depending on what your main goal is, you could add them to the G-list if there are not to many of them. Have you been able to determine on which head the slower sectors reside on?
PostPosted: July 2nd, 2010, 15:36
More than to G-list I suggest to :
1) ERASE (zerofill) HDD first as new adaptives are being used and rescan : most probably the problem is solved
2) if no joy, instead of adding to G, add to P all "delays".
3) depending on many things, at the end of SS you have defects added to G and still P empty : in this case shift G to P... voila - the drive is fixed
... or the drive has really bad surface.
PostPosted: July 3rd, 2010, 12:43
BlackST: Run selfscan before cleared the P-List, selfscan completed, P-list a large amount of data, you can run the user area of the calibrate it?
PostPosted: July 3rd, 2010, 15:55
It is normal that p-list is filled and you have a lot of entries - the drive is large! . Yes, you can try internal format after - if I understood correctly. Sometimes some adaptation of the script or a custom made one can help, it depends on surface conditions. BTW, if there are errors still 'concentrated' on definite areas, why not work on zones ?
Users browsing this forum: Bing [Bot] and 65 guests
