 Post subject: Hitachi 80GB HDS728080PLAT20 PCB SWAP
PostPosted: July 6th, 2010, 15:08
Is this donor drive is fair ? pcb swap doesn't work, drive spin up normally but no caliberation...
VICTIM DRIVE:
MODE : HDS728080PLAT20
P/N : 0A30217
MLC : BA1773
May 2006
DONOR:
P/N : 0A34101
MLC : BA1773
Nov 2006
Help would be highly aprpeciated
RAID/Server Recovery
 Post subject: Re: Hitachi 80GB HDS728080PLAT20 PCB SWAP
PostPosted: July 6th, 2010, 20:06
Assuming that the PCB is the point of failure, you'll need to move the NVRAM chip from the original PCB to the donor.
PostPosted: July 7th, 2010, 5:16
I found NVRAM at U5 6 pin, and transplant it, and it work just fine.
thanks for the confirmation.
It worked.
