 Post subject: seagate 7200.10 PATA not found in BIOS
PostPosted: July 13th, 2010, 17:09
hi ive searched the forums but cant find the answer to this.
hdd info
seagae barracuda 7200.10 PATA 500GB
s/n ST3500630A
p/n 98J046-305
f/w 3.AAE
Date code 07407
site code WU
made in china
the drive spins up clicks every few seconds for a couple of mis then turns itself off. when on a usb adaptor & is not recognised by the BIOS when fitted in a pc. i just want to run it to get the data off it then it can go in the bin.
seagate dont have this drive listed for free data recovery.
ive read about the rs232 & hyperterminal but this seems to be for SATA drives not PATA.
any help would be apprecated.
Dan
 Post subject: Re: seagate 7200.10 PATA not found in BIOS
PostPosted: July 13th, 2010, 17:32
This drive is 7200.10 not 7200.11 (the one which suffers from the FW problem fixable by RS232)
Sounds much more like bad heads on this one.
The more you hammer it with bad heads, the more chance of the platters being damaged and lessening the recovery chances.
PostPosted: July 13th, 2010, 17:33
Not recognized in BIOS is not a good thing. Most likely damaged. Clicking is most likely "Click of Death". If the data is very important get professional help otherwise move on to a new drive (or two, one for backup :D ). Was it dropped?
HWHacker
Smiles
PostPosted: July 13th, 2010, 17:34
Indeed, like the heads have failed.
Not a DIY fix I'm afraid, seek your nearest pro, there are a few guys from the UK on this forum who can help you for a reasonable fee. Be prepared, DR on a physical drive is not cheap.
Data Recovery Ireland
PostPosted: July 13th, 2010, 17:35
100% heads problem / SA (or both). No DIY.
PostPosted: July 14th, 2010, 12:59
thanks for the help, any one got any idea how much this is likley to cost. as i said i dont want the drive & ill supply somwhere to put the data i just want the data back.
many thaks for the quick replys Dan
Users browsing this forum: Google [Bot], Rendersmith and 75 guests
