 Post subject: PCB swap on IBM DeskStar 40GB (IC35L040AVER07-0)
PostPosted: July 9th, 2010, 18:11
I have an old IBM DeskStar 40GB hard drive that died on me. Model: IC35L040AVER07-0
Is a PCB swap possible for this model? I do know newer models require transfer of the NVRAM, is that the case with these older drives as well?
I believe the problem with the drive is PCB related, although I am not sure. Symptoms:
- Drive spins up normally
- Detected in BIOS - Capacity detected as 32254GB (should be ~38146MB)
- Only first 480MB accessible, trying to access anything beyond the first 480MB gives an immediate error.
- Partition information intact
- Boot sector intact
- Partition refuses to mount (I'm assuming this is due to the inability to access beyond the first 480MB of the drive)
 Post subject: Re: PCB swap on IBM DeskStar 40GB (IC35L040AVER07-0)
PostPosted: July 9th, 2010, 19:38
It is not the pcb most probably.
PostPosted: July 9th, 2010, 20:30
Any idea where the problem is then?
Users browsing this forum: Google [Bot] and 63 guests
