 Post subject: Help
PostPosted: July 17th, 2010, 11:20
Hi
I also have the misfortune of a crashed hard disk, in fact 2 harddisks!
The cause: a faulty PSU!
I smelled the burning PCB of the Harddisk and new this was very bad.
SO I am looking for a replacement for the board for a WD10EADS (28/12/2009 ) and a STM325031as but also i have some questions.
After reading in your forum its not just a question of replacing the PCB with a new one?
There are unique codes in the circuit logic linked to the software on the disks?
I appreciate your advice in how to retrieve my data
 Post subject: Re: Help
PostPosted: July 17th, 2010, 14:05
Dobre is in Belgium I would send him a PM. Just have the drives looked at by him and see what he can recommands on this one. WD drive is not such an easy one to work on as it is and if the PCB is actually bad there could (I am not saying there is) be other damage on the inside of this drive.
Other wise post here the specs from the label of both drives plus the specs on the two PCB boards. Make sure you give the number that is printed on the PCB board for WD. This one is important. The other you can get from the stickers on the PCB board. There are people here that sell parts and will contact you on this one.
Last option you can follow Frank on this one. I am sure he will post here soon. Be sure to read the posts here on the forum and especially the one from the guy in Greece who tried to do this work himself and see what happened to him. Good luck on this one
Iorana Haraharaini
PostPosted: July 17th, 2010, 19:16
for WD10EADS you had to do FW transfer from bad PCB to good PCB with special tools.
for STM325031as you had to soldering ROM chip from bad PCB to good PCB by yourself or get someones help.
data recovery service[/b]
PostPosted: July 18th, 2010, 1:55
Plus ,
They Are Already Fried ,So In The WD10EADS Its even More Harder .
PostPosted: July 18th, 2010, 4:29
If you upload detailed photos of both boards, one of us will help you identify the faulty components.
The usual fault is a shorted diode which can simply be removed, in which case the repair will cost you nothing.
Good luck.
Search this forum and the forums at Seagate and WD for "TVS diode".
PostPosted: July 18th, 2010, 10:46
Good luck.
Sir ,
Lets Make a Small tutorial On this And Post It In HDD Guru .What All Makes Of TVS Have You Come Across .
PostPosted: July 18th, 2010, 12:11
OK here are the hdd
The SEAGATE HDD has a sticker with number
100471144 E k843E4MB
His pic of the PCB, please note that the component that is defect (diode?) is completely gone!
The Western digital has a sticker with number
2061-701640-202 03PD3 XT 8R22 L2PP 6 0005230
His PIC of the PCB:
Here the smooth chip seems to have the damage:
PostPosted: July 18th, 2010, 12:13
wat is his pm?
PostPosted: July 18th, 2010, 12:26
powerbits wrote:
OK here are the hdd
His PIC of the PCB:
sir ,
Kindly Read whats Written On top of 8 Pin IC Of All Two PCb And Report back .
PostPosted: July 18th, 2010, 13:25
on the seagate hdd i see 2 8 pins chips:
ic1 ON seagate
ATMEL810
25FS12AN
SH27
ic2 on seagate
hjaj
fd8
2p102a
on the wd i have one 8pins ic:
ss7 25l-f02oa
33-4c-sae
0944217-ab
PostPosted: July 18th, 2010, 14:23
ic1 ON seagate
ATMEL810
25FS12AN
SH27
ic2 on seagate
hjaj
fd8
2p102a
ss7 25l-f02oa
33-4c-sae
0944217-ab
Hi ,
IC Number One Should be desoldered and go to new pcb ,Not Sure Of WDC ,But i think it should Too [ It Seems a Serial Flash Ic ]
PostPosted: July 18th, 2010, 15:32
IF the preamps still work...
PostPosted: July 18th, 2010, 18:16
The Maxtor/Seagate board has sustained a hit on the +5V supply.
This is what the board should look like:
http://ep.yimg.com/ca/I/yhst-4446369223 ... 12_1071555
If you would like to attempt a DIY repair, then remove the smaller of the two diodes (the one to the left of the KVP part). This is the 5V TVS diode. Then replace the damaged inductors (?) with wire links.
Otherwise a replacement PCB is available here:
http://www.onepcbsolution.com/stm325031 ... v548a.html
The above vendor offers a ROM transfer service for $10.
PostPosted: July 18th, 2010, 20:24
The serial EEPROM chip on your WD board is this one:
SST25LF020A, 2 Mbit SPI Serial Flash, Silicon Storage Technology, Inc:
http://www.semiconductorstore.com/pdf/n ... SAE_DS.pdf
Do not be unnerved by the attempts to intimidate you into engaging a professional service unless it's really necessary. Remember, you are most vulnerable when you've lost something precious. In that respect data recovery is a bit like the funeral industry, except that they offer to resurrect your loved one . :-)
BTW, if your DIY attempts fail, don't post back. You'll be the butt of merciless ridicule, even if your workmanship is perfect. The DR people will attempt to place the blame on you or me, and then attempt to profit from your failure by intimidating others. I can show you one example where a DR company quoted $1400 to recover data from a drive with a shorted diode. Instead, the owner opted for a simple DIY repair which cost him nothing.
PostPosted: July 19th, 2010, 5:46
ok guys but about the seagate board
Wat do i replace exactly with wich components.. i have some older HDD where i would pick of the good component
Users browsing this forum: Bing [Bot], Google [Bot] and 99 guests
