 Post subject: is that PCB problem?
PostPosted: July 27th, 2010, 11:29
hello. i have a Maxtor Plus8 40Gb. i connect it to the ddi and it is not recognised (the model and LBA when i press F11)
there is only an ERR report. i supose there is a PCB issue. any help would be appreciated
 Post subject: Re: is that PCB problem?
PostPosted: July 27th, 2010, 11:34
That model does not have PCB problems usually. Chance of PCB failure is 1 in a 200.
www.datarecoveryne.com
PostPosted: July 27th, 2010, 13:46
Agree more than likely it is in the modules of this drive. Do you have any other tools to work in the SA and fix this one with?
Iorana Haraharaini
PostPosted: July 27th, 2010, 15:36
Did you make sure that the drive jumpers are set for master?
PostPosted: July 27th, 2010, 17:45
do you have report of others tools?
data recovery service[/b]
PostPosted: July 28th, 2010, 1:58
Check jumpers and try with Mhdd, if no joy check pcb then SA.
