 Post subject: Maxtor 6Y080L LBA 0
PostPosted: August 2nd, 2010, 5:48
Good Day,
I have a Maxtor HDD 6Y080L LBA 0, h important data, please help me.
I read that the TTL to RS232 interface I can solve, but do not know the jumpers TX and RX, if someone helps me.
 Post subject: Re: Maxtor 6Y080L LBA 0
PostPosted: August 2nd, 2010, 6:21
Sorry to tell you but you are barking up the wrong tree! Wrong diagnosis!
You have confused one of the repair proceedures for a very different model with your own model.
The pro's here will tell you this is unlikely to be a diy job.
PostPosted: August 2nd, 2010, 6:24
Quel modello non si connette via terminale come pensi (non e' un seagate barracuda). Il drive e' visto come MAXTOR CALYPSO per caso all'avvio e poi viene segnalato un problema sul disco ? Se e' cosi', e' un problema interno non risolvibile se non con apportuni strumenti e conoscendo il problema. Se ti serve recuperare i dati , contattami via PM.
That model has no terminal connection as you think (it's not Seagate Barracuda).
The disk is recognised as MAXTOR CALYPSO at start and then the PC tell you that there is a problem on disk ? If so, it's internal problem that require specialized equipment and knowing what to do. If you need data, PM me.
PostPosted: August 2nd, 2010, 10:11
as BlackST said. it's no like Seagate diagnostic via TTL. send it to some one for help if it really important for you. good luck :)
data recovery service[/b]
Users browsing this forum: Google [Bot] and 77 guests
