 Post subject: WD5000AAKS Issue
PostPosted: August 2nd, 2010, 20:13
After doing some searching... it appears that the board going bad on the WD5000AAKS is a common issue. Here is what I have..
If I swap that out from another WD HDD... does it have to be the exact same for it to work or will anything work? I think the board is 2060-701477-002 Rev A. Also, is it possible to find a replacement one of those anywhere?
 Post subject: Re: WD5000AAKS Issue
PostPosted: August 3rd, 2010, 1:55
90 percent of problems encountered is heads... No a straightforward swap won't work.
PostPosted: August 3rd, 2010, 3:43
i am agree with BlastST it might be Head Problem direct PCB swap will not work for this board u need special Device to access it's Firmware like salvation or Pc3000.
PostPosted: August 3rd, 2010, 8:12
the condition of the pcb is very bad, why is it so ? is it water damaged pcb ?
RAID/Server Recovery
PostPosted: August 3rd, 2010, 8:16
I have no idea how it happened. The hard drive is almost never out of the case, and when it is, no where near water, and my case is air cooled.
How did you guys come to the conclusion on it being a head issue, if you don't mind me asking?
PostPosted: August 3rd, 2010, 9:14
Because we have experience and we do DR for a living. PERIOD. :D
Jokes apart (but not quite so :D ) , normally these drives fail without notice because of heads and maybe HEADS that damage the firmware. I cannot judge the conditions of the PCB, but if the drive clicks and spindown , heads / firmware are 1st.
There is a SAFE way to check PCB but require dedicated equipment, other ways are risky so I won't talk about it (unless you can take into account screwing ROM or make further damage to the firmware).
PostPosted: August 3rd, 2010, 9:29
P.S. sorry for one post after another : the PCB seems OK, what you think is "oxide" is normal . From pictures, seems a normal Pb Free PCB finish although it seems oxidized. At least from pictures.
It is quite normal reaction to air on these new RoHS / PbFree PCBs. But I can be wrong, I should see it with my eyes and maybe make a measurement / check it.
PostPosted: August 3rd, 2010, 10:10
There are different type of problems in hard drive;
1). PCB
2). Head
3). Firmware
4). Motor Seized
5). Media Scratch
Your drive can have anyone of those, unless it is examined by a pro, however, Gurus here have the best experience and there guess without checking the drive can be the closest.
Give details of the drives health before it died, may be it will help to give you more details..
PostPosted: August 3rd, 2010, 12:15
Hmm... I see. Well the drive is working as of right now, so I'm in the process of copying all my data off of it. I wasn't aware that, that was a normal thing to see with the discoloration of the board.
PostPosted: August 3rd, 2010, 12:22
the colour of the board is quite normal for WD of that type sadly.
PostPosted: August 4th, 2010, 0:17
You can close this thread or whatever. The drive functioned long enough today where I was successfully able to clone it and lost no data. I'll just RMA it with WD now.
PostPosted: August 4th, 2010, 3:02
how the drives comes ready by itself, can u share please ?
PostPosted: August 4th, 2010, 5:35
Sometimes happens.
PostPosted: August 6th, 2010, 4:24
And the procedure is called Luck . :lol:
PostPosted: August 6th, 2010, 8:52
rameez, you are right..
i suspect doing something to the pcb solve the problem.
"LtLawl" can clear this
PostPosted: August 7th, 2010, 18:36
Yeah just pure luck. Haha. I did consider the freezer trick though. :lol:
Users browsing this forum: Google [Bot] and 39 guests
