 Post subject: WD3200JS-57PDB0
PostPosted: August 18th, 2010, 9:52
I have one of the above drives.
It does not spin up. Using a DVOM there is no voltage being applied to the motor connectors.
Is it likely the PCB? If so:
I see a PCB swap is unlikely to match unless it's exact. So can the proper firmware be written to another PCB?
The data on the drive is unimportant.
Can/does anyone here offer that service?
 Post subject: Re: WD3200JS-57PDB0
PostPosted: August 18th, 2010, 10:15
Do you want to repair the drive?
Is that your purpose?
If so, to be honest doesn't make a lot of sense, because you'll spend more money buying a compatible PCB and swap ROM chip than to buy a new 1Tb drive.
PostPosted: August 18th, 2010, 20:04
The drive is from a DVR recorder. It seems it must be this very part #. A replacement is difficult to locate.
PostPosted: August 19th, 2010, 3:56
I'm not a DR guy, but maybe the differences are in the EEPROM rather than the MCU, so a ROM transfer may solve the compatibility issue. If the EEPROM is external to the MCU, a ROM transfer should cost you $10 - $20.
However, before purchasing a PCB, I would measure the resistances of each of the motor windings.
Have you tried http://www.onepcbsolution.com/ ?
If you intend to replace the whole drive, you may need to determine if there is a software zone in the user area. Some DVRs load their runtime code from the HD.
FYI, I have found the following support site to be one of the best:
http://www.videohelp.com/
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 278 guests
