 Post subject: Protection Diode
PostPosted: August 10th, 2010, 5:54
Hello
Can somebody write how works
diode with label 'N'
and diode with label 'S'
(small green)
 Post subject: Re: Protection Diode
PostPosted: August 10th, 2010, 15:12
The labels is called a "top mark" if you have a top mark directory you can get the real world part number for the diode. Then the data-sheet and all the info. But in general there are two types of protection diodes. first is Schottky the second is Zenner. The Schottky has a low forward voltage drop and is used to protect from power reversals. The Zenner has a set voltage at which it begins to conduct in reverse. This limits the maximum supply voltage. There is a third type of "Diode" that is not really a diode but a Diac. It will go from an open to a short if its brake-over voltage is exceeded.
Hope this helps
HWHacker
Smiles
PostPosted: August 10th, 2010, 15:16
http://en.wikipedia.org/wiki/Transient_ ... sion_diode
PostPosted: August 17th, 2010, 8:29
I suspect that the OP may be referring to smt fuses, not TVS diodes.
Littelfuse Surface Mount Fuses, N = 2A, S = 4A:
http://www.farnell.com/datasheets/48294.pdf
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 102 guests
