 Post subject: ST3500320AS 7200.11 tvs part identification
PostPosted: August 9th, 2010, 7:13
i recently bought a harddisk (seagate barracude OEM with a ST3500320AS 7200.11 pcb board) which just before i bought it held a barbecue. upon taking the pcb board out, i saw a nice burning mark, exactly where the tvs is/should be (at least what was left of the tvs). not knowing a lot about harddisks, i came across this forum. apparantly a harddrive can work without the tvs, so i soldered the tvs off. after which the harddrive worked again like a charm. spinned up, my external casing recognised it again and it was alive.... but, i would like to solder another tvs back in place. but, the old tvs was burned (print was melted), so i don't know what 'kind' of tvs it was.
i have an old ide hdd laying around with bad platters, i can solder the tvs off that drive. but, i am not sure what the tvs is. i am guessing that it is the one the closest to the power connector (there is only one 'black rectangle' that can qualify as a tvs), but is there only one? shouldn't there be 2 (on for the 5 volt line and one for the 12 volt line?).
off course the bbq drive is a sata drive, the donor drive is an old 8 gig ide drive. can i just take the tvs of the old 8 drive and solder it onto the sata pcb board? how to identify whether it is a 5 or 12 volt tvs (assuming that makes any sense, e.g. that there are 2 tvs's. i might be wrong off course). and i assuming, a tvs being a diode, that i should solder it the right direction (being it a diode, and having a anode and cathode side). if so, which side is the anode and which one is the cathode? (both on the tvs itself, and on my sata pcb (ST3500320AS 7200.11)). a lot of questions, and hopefully a lot of answers. as far, this forum helped me out getting the drive working again so far. so i have good hopes.
it is the exact pcb board in the picture (on this forum) at post 8 (it is the tvs just to the upper right that is burned):
st3500320as-7200-fried-t10453.html
 Post subject: Re: ST3500320AS 7200.11 tvs part identification
PostPosted: August 17th, 2010, 9:22
The TVS diode near the edge of the PCB is the 12V diode. The other part is the 5V diode.
You can replace the 12V diode with an SMBJ12A from Farnell, Mouser, Digikey. Line up the striped end with the "v" on the PCB.
Here is the pinout of the SATA power connector:
http://pinouts.ru/Power/sata-power_pinout.shtml
My notes should help you identify the components:
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
Users browsing this forum: Google [Bot] and 50 guests
