 Post subject: WD3200BEKT
PostPosted: August 25th, 2010, 10:03
Hi to all!
Four heads, is one bad (0-good, 1-good, 2-good, 3-BAD)
How do I get the most files without changing the heads?
Thanks!
Нет ничего невозможного
 Post subject: Re: WD3200BEKT
PostPosted: August 25th, 2010, 10:23
75% clone is easily achieved with 3 good heads. I find it hard to believe that considering how long these Marvel WD's have been around, and as you have been here in the forum for such a long time, that you have not worked with such a case.
PostPosted: August 25th, 2010, 10:26
Ok, thanks for reply! :mrgreen:
Clone is started...
PostPosted: August 25th, 2010, 10:48
The answer seemed to help :mrgreen:
PostPosted: August 25th, 2010, 11:03
to answer in full if u are using PC3k with DE u need to build headmap and just swich off the bad head in task params.
Udaci.(good luck )
PostPosted: August 25th, 2010, 11:34
I agree partially because this answer is valid only if disk is correctly identified and accessible. In most situations even a single bad head can prevent the disk from proper initilisation and will instead stop spindle preventing access.
Sempre did not give enough detail on the symptoms to get a valid and relevant answer. Any detailed answers would have been based on guesswork, and likely have not been accurate.
I am pleased my vague answer helped though 8)
PostPosted: August 25th, 2010, 12:02
Safe mode - work with rom - rom head map - turn bad head off - normal mode and init =)
PostPosted: August 25th, 2010, 12:20
Disable bad head in ROM will init disk with 3 heads instead of 4. Zones will change sizes, and H0 will read only for several thousand sectors, then at time of head switching, all sectors will be inaccessible.
ROM head map is not the way, unless of course SA modules need to be read for Smart HotSwap.
PostPosted: August 25th, 2010, 13:03
My apologies. What i should have wrote was RAM head editing.
PostPosted: August 25th, 2010, 14:19
Thanks all helps!! :mrgreen:
Started clone in DE UDMA (head 3 disable)
PostPosted: August 25th, 2010, 16:36
Without head 3 your data will not be that great due to the way data is written to the drive, especially if the client is looking for larger files. Most likely you will need to swap out the heads once you get the other 3 heads read in to get a much better recovery.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 250 guests
