IBM Travelstar 20 GB
June 21st, 2010, 16:29
I have a IBM Travelstar 20 GB IC25N020ATDA04 from a client.
In the beginning, we can read the disk ... several minutes later we can't access the disk. Lots of bad sectors - with Victoria.
At moment no access (1 week later). Start the spin for several times and then shutdown.
I need some advise.
Thanks in advance
Neuron
Re: IBM Travelstar 20 GB
June 21st, 2010, 16:53
Head gone is first thought that comes to mind (was weak and definitely gone).
Probably you have also media damage too.
Check SA for readability then make visual inspection with microscope.
June 21st, 2010, 17:19
buy yourself a PCB and try that
June 21st, 2010, 17:35
BlackST wrote:Head gone is first thought that comes to mind (was weak and definitely gone).
Thank you for your comments: BlackST, guru.
So first try exchange the PCB, if no luck ... then clean room.
Thanks for the quick answer.
Neuron
June 21st, 2010, 19:01
hi neuron,
why do you think it's PCB? any symptoms?
June 22nd, 2010, 2:42
I myself have had a few "IC25N020ATDA04" in the past that had these exact symptoms which had a faulty PCB ;o)
But it's 50/50 !
June 22nd, 2010, 10:40
The fact that it was "working" (albeit badly) then a lot of bads.... PCB do degradate that way ? (Oh, everything can be....)
June 22nd, 2010, 16:20
yep I have seen exact problem (although it may not be the problem). Made me crazy when trying to recover the drive.
For example
Drive works fine, then a few bad sectors then it would knock. Culprit was PCB (maybe a problem with spindle speed control)
June 23rd, 2010, 16:54
guru wrote:yep I have seen exact problem (although it may not be the problem). Made me crazy when trying to recover the drive.
For example
Thanks .......... for yourrrrrrrrrrrrrrrrr commentssssssssssssss,
The disk and the human is in Europe - > Portugal.
Anyone near with a similar disk ?
I need to get an exact model and year or we can match only the model?
Best regards,
Neuron
October 31st, 2010, 18:21
guru wrote:I myself have had a few "IC25N020ATDA04" in the past that had these exact symptoms which had a faulty PCB ;o)
But it's 50/50 !
Hi guru,
Thanksssssssssssssssssssssssssssssssssssssssssssss
Changed PCB and we recovered all data.
ddrescue - MacOSX and copy all data. Company data and some research project.
Another client happy.
Thanks on more time,
Neuron
