 Post subject: File Allocation Table Error in Scandisk
PostPosted: March 24th, 2011, 16:15
Hey all!
I have this problem, does anyone have its solution.
"This drive contains one or more back-up copies of the file allocation table (FAT). The copies should be identicle but aren't."
I choose the selection to "Repair the error"
Then scandisk continues its check and finishes saying that "Scandisk found errors on the drive and fixed them all."
However, if I run scandisk again it still has the same error. I've tried both standard mode and thorough mode, but again it still comes up with the same error.
So, what does this problem mean and, most importantly, how do I fix it?
Regards,
Abid Hafeez
+92-300-4507434
abid_hafeez@hotmail.com
 Post subject: Re: File Allocation Table Error in Scandisk
PostPosted: March 24th, 2011, 16:58
Is this your drive or from a customer?
Is it an external or internal drive?
What events happened immediately before scandisk first reported a problem?
Have you checked the Windows event log for any errors which are being logged, at the date/time when scandisk is run?
Have you cloned the drive already?
Are you aware that running scandisk can cause loss of normal access to one or more files, requiring logical data recovery?
PostPosted: March 24th, 2011, 23:21
I would copy the FATs to separate BIN files (on another drive), and then compare them. To this end, could we see the partition table and boot sector with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt.
PostPosted: March 24th, 2011, 23:39
@fzabkar - Nice plan. :) I was going to suggest that the OP compared the FATs, but decided to start by asking some "baby steps" questions instead, due to the missing context for the current situation. Perhaps I aimed too low. :(
PostPosted: March 25th, 2011, 2:25
Hey fzabkar!
I tried SecInspec but its giving me some error as fillows:
rem Author: Starman
rem http://mirror.href.com/thestarman/asm/m ... tm#SecInsp
@echo off
if exist secinspect.exe goto okrun
echo.
echo.
echo Did not find secinspect.exe in this folder, you
echo must place secinspect.exe in the same folder as
echo SIrun.bat for me to work.
echo.
echo Press any key to close this window.
pause > nul
goto close
:okrun
echo -------------- >> SIout.txt
echo Date and time: >> SIout.txt
date /t >> SIout.txt
time /t >> SIout.txt
echo. >> SIout.txt
secinspect.exe >> SIout.txt
start notepad SIout.txt
:close
exit
What to do with it?
And Vulcan ofcourse this is my customer's drive.I don't want to recover data from it,just want to repair.I don't have its history.
Regards,
Abid Hafeez
+92-300-4507434
PostPosted: March 25th, 2011, 4:31
Abid, Sector Inspector doesn't appear to run on a Win9x box. Is that your problem?
Otherwise it appears that you are dumping the SIrun.bat file rather than running it. Try changing the name to SIrun.cmd, or choose Open from the r-click context menu in Explorer.
Alternatively, you can use a disc editor such as HxD to examine sectors 0 and 63.
BTW, if the data are of no value, then why don't you just reformat the drive? :?
PostPosted: March 25th, 2011, 12:12
Why "of course"? You didn't say this at the beginning...
That's a pity for you, since having the history often makes troubleshooting more efficient (especially when trying to assist someone remotely, like you are now requesting here).
I have seen this scandisk behaviour before, but since you didn't answer any of my other questions, then further help from me is impossible. :(
Users browsing this forum: Google [Bot] and 71 guests
