 Post subject: Noob
PostPosted: August 31st, 2010, 8:54
I need help with diagnostics and repair. Advanced System Care's Disk Doctor reports a bad indexing on my hard disk but fails to repair it as the problem remains after repair by chkdsk, boot time is extremely slow. I am running a Compaq Presario F761 US NoteBook PC.
Here are my Hard Drive Specs
Model: Hitachi HTS542516K9SA00
Firmware: BBCOC32P
Report By: HDDScan for Windows version 3.3
Report Date: 8/31/2010 5:49:30 AM
Num Attribute Name Value Worst Raw(hex) Threshold
001 Raw Read Error Rate 100 097 0000000000-0000 062
002 Throughput performance 100 100 0000000000-0000 040
003 Spin Up Time 253 100 0000050000-0000 033
004 Start/Stop Count 098 098 0000000000-0DB5 000
005 Reallocation Sector Count 100 100 0000000002-000D 005
007 Seek Error Rate 100 100 0000000000-0000 067
008 Seek time Perfomance 100 100 0000000000-0000 040
009 Power-On Hours Count 085 085 0000000000-1A05 000
010 Spin Retry Count 100 100 0000000000-0000 060
012 Device Power Cycle Count 098 098 0000000000-0D73 000
184 End To End Error Count 100 100 0000000000-0000 099
187 Reported Uncorrectable Error 099 099 000000007F-0001 000
188 Reported Command Timeouts 100 100 0000010004-0001 000
190 Airflow Temperature 050 038 50 C 000
190 Airflow Temperature Minimum 050 038 44 C 000
190 Airflow Temperature Maximum 050 038 52 C 000
191 G-sense Rate/Servo tracking 097 093 0000000005-0001 000
192 Emergency Retract Count 098 098 00000001AB-01AB 000
193 Load/unload Cycle Count 094 094 0000000000-FE41 000
194 HDA Temperature 110 088 50 C 000
194 HDA Temperature Maximum 110 088 62 C 000
194 HDA Temperature Minimum 110 088 13 C 000
196 Reallocation Event Count 100 100 0000000000-0002 000
197 Current Pending Errors Count 100 100 0000000000-0000 000
198 Uncorrectable Errors Count 100 100 0000000000-0000 000
199 UltraDMA CRC Errors 200 200 0000000000-0000 000
223 Load Retry Count 100 100 0000000000-0000 000
Windows Vista
English (United States)
C:\ Volume Label: Local Disk, File System: NTFS
Disk Check is verifying files (stage 1 of 3)...
131456 file records processed.
File verification completed.
157 large file records processed.
0 bad file records processed.
0 EA records processed.
60 reparse records processed.
Disk Check is verifying indexes (stage 2 of 3)...
Index entry 00010004.ci in index $I30 of file 121563 is incorrect.
Index entry 00010004.dir in index $I30 of file 121563 is incorrect.
Index entry 00010004.wid in index $I30 of file 121563 is incorrect.
167082 index entries processed.
Index verification completed.
Errors found. Disk Check cannot continue in read-only mode.
 Post subject: Re: Noob
PostPosted: August 31st, 2010, 9:50
Plug it in as an external or slave, and use recovery software on it, such as Get Data Back NTFS or R-Studio. There is plenty of free software out there as well.
Users browsing this forum: No registered users and 284 guests
