 Post subject: Please Help me
PostPosted: September 1st, 2010, 10:11
I have 80gb seagate 2.5 hdd. I've tested it with HDD regenerator and it showed me that after 70 gb only bad sectors. How to block read and write to sectors between 70-80 gb? is it possible? how to fix it?
 Post subject: Re: Please Help me
PostPosted: September 1st, 2010, 10:35
HDD Regenerator will in 99% of cases not help, and will potentially make things worse.
If you have this volume of errors, you should not realy be considering a repair. Make a backup of your data and buy a new disk.
No point attempting to repair this one.
PostPosted: September 1st, 2010, 10:37
If you must, you could set an HPA, reducing the available size of the disk.
PostPosted: September 1st, 2010, 10:38
Please explain how?
PostPosted: September 1st, 2010, 10:40
MHDD can do it
Users browsing this forum: Google [Bot] and 252 guests
