 Post subject: Fujitsu 2,5" IDE MHS2040AT
PostPosted: September 2nd, 2010, 6:39
Hi
I have this disk that isn't recognized by BIOS or even the SD Doctor. It spins OK, no noises, but not detected. Is this PCB or FW error?
ACELab partner
 Post subject: Re: Fujitsu 2,5" IDE MHS2040AT
PostPosted: September 2nd, 2010, 7:08
Im pretty sure that the MHS series suffer with the same problems as the MPG/MPF series. Been a while though so cant be certain.
Can you read SA modules at all? Im not familiar with SD doctor for Fujitsu so am not sure how (or if :D ) it works.
PostPosted: September 2nd, 2010, 7:49
No, I can't read it. Doctor says NO HDD :? :?
ACELab partner
PostPosted: September 3rd, 2010, 7:07
No opinions about this?
ACELab partner
PostPosted: September 3rd, 2010, 11:39
We seldom see firmware problems on 2.5" Fujitsu drives. Yes, it could be the PCB but more likely heads are the issue. You can check the PCB by getting a donor of same model with same firmware version.
Users browsing this forum: No registered users and 307 guests
