 Post subject: how to recover deleted data from server HP DL 350
PostPosted: September 20th, 2010, 4:09
We have a Server HP model DL 350 Server (not use disk IDE, and a kinds power cable is not like others), there are only installed the CDROM /DVDs, also installed four pieces hot swap SCSI HDD @ 146GB, using operating system : the Fedora Linux OS/ext3, The system was readable three volume set: 1. a volume set of space 10 GB as ext3 for the system, 2. set of 2 GB volume as ext3 unreadable, 3. The system readable volume set of approximately more than 300GB as ext3. My case was just deleted data from the network clients. How to recovery for lost data has been deleted, any step to do, if use a software, where I can download ? Give me right solution, please... thanks. Arnel
technical support, Jakarta.
 Post subject: Re: how to recover deleted data from server HP DL 350
PostPosted: September 20th, 2010, 4:19
If the files were just deleted, you can try TestDisk: http://www.cgsecurity.org/wiki/TestDisk
ACELab partner
 Post subject: we have try but It I can not recover lost data (deleted data
PostPosted: September 22nd, 2010, 1:11
I have try a testdisk tools but It I can not recover lost data (deleted data). Any solution for recover data from my server?
Thx
Leo.
Everesta
PostPosted: September 22nd, 2010, 4:10
everesta wrote:
My case was just deleted data from the network clients..
Are you sure that it was deleted by somebody from the network? Or it is just disappeared?
Someone from clients confessed?
Angel Data Recovery
Users browsing this forum: No registered users and 53 guests
