 Post subject: Western Digital Cavier 500 GB External Hard Drive HELP ME
PostPosted: September 22nd, 2010, 0:19
Hello.
I have an external hard drive. I was using to transfer some files for backing up to it. I had it decide to not respond half way through the transfer. I terminated the process.
After that the hard drive would show up in windows, but was unaccessable.
I tried CHKDSK and it did not work.
I tried EASUS Partiton Recovery and it displayed all the files on the drive. I double clicked one of them and it opened a picture from my drive. All of a sudden it said not responding for a long time. I powered down the external and now it does not show up in my computer anymore.
It does not display and files anymore with my recovery software, I have tried many. It tried to re-install the windows driver when I hooked it up again (weird) and said it was not installed successfully.
Now my 500 gb drive shows up only as a physical drive in the rcovery software. It also now sys it is a 2 TB drive not 500 GB.
Is this recoverable? How? I hope for this data so badly... PLEASE HELP ME!!!!
 Post subject: Re: Western Digital Cavier 500 GB External Hard Drive HELP ME
PostPosted: September 22nd, 2010, 0:29
it will be wise to image the drive first if possible, then use r-studio etc..
RAID/Server Recovery
PostPosted: September 22nd, 2010, 1:38
won't work. 9 out of 10 it's head problem and/or fw as it is seen 2tb. Only hope it's weak head intermittent failure. When works, get out as much and as fast as possible.
PostPosted: September 22nd, 2010, 4:25
How does Microsoft's UVCView utility identify the the USB enclosure, with and without a drive installed?
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
Can either of the following tools see the drive in the enclosure?
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
Does the drive appear in BIOS if you connect it directly to your motherboard's SATA port?
PostPosted: September 22nd, 2010, 7:50
Cant image it, I dont have a drive 2TB as that is what the pc thinks it is.
PostPosted: September 22nd, 2010, 21:06
with drive installed in enclosure
uvc view:
English product name: "USB to ATA/ATAPI Bridge"
ConnectionStatus:
Current Config Value: 0x01 -> Device Bus Speed: High
Device Address: 0x01
Open Pipes: 2
===>Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x05
bEndpointAddress: 0x81 -> Direction: IN - EndpointID: 1
bmAttributes: 0x02 -> Bulk Transfer Type
wMaxPacketSize: 0x0200 = 0x200 max bytes
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x02 -> Direction: OUT - EndpointID: 2
bInterval: 0x00
===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0x00 -> This is an Interface Class Defined Device
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 = (64) Bytes
idVendor: 0x152D = JMicron Technology Corp.
idProduct: 0x2329
bcdDevice: 0x0100
iManufacturer: 0x01
English (United States) "JMicron"
iProduct: 0x02
English (United States) "USB to ATA/ATAPI Bridge"
iSerialNumber: 0x05
*!*ERROR: no String Descriptor for index 5!
bNumConfigurations: 0x01
===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x0020 -> Validated
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x04
*!*ERROR: no String Descriptor for index 4!
bmAttributes: 0xC0 -> Bus Powered
MaxPower: 0x01 = 2 mA
===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x02
bInterfaceClass: 0x08 -> This is a Mass Storage USB Device Interface Class
bInterfaceSubClass: 0x06
bInterfaceProtocol: 0x50
iInterface: 0x06
*!*ERROR: no String Descriptor for index 6!
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x00
PostPosted: September 22nd, 2010, 21:09
they can both see the drive but no info or anything can be performed...
PostPosted: September 22nd, 2010, 22:07
every sector reads error. It is a prety new drive. I dont understand.
I cannot bypass the enclosure because it is SATA and I am ATA internal. Is there an adapter avail?
PostPosted: September 23rd, 2010, 9:02
I told you so :
ALL THE REST IS TOTAL BULLSHIT.
Do you really want to diagnose it yourself at your own risk (BEWARE : tinkering with a failing drive with unknown failure reason CAN POTENTIALLY DESTROY OTHERWISE RECOVERABLE DATA) ? If so ...
PostPosted: September 23rd, 2010, 9:07
@ kungfuthug,
Did you try to put your ears on the drive and hear it spin ?
Normal calibration, bzzzz, clicking ..... etc ?
PostPosted: September 23rd, 2010, 22:30
It spins yes, no clicking sound like it normally would. It just spins. The driver is not installing correctly when I plug it in either.
At this point I dont care if I lose the files tinkering with it, because I will never pay hundreds to have it recovered professionally. So any freshh ideas would be appreciated...
thx
PostPosted: September 23rd, 2010, 22:31
All the problems happened while transfering files from Liux Ubuntu. It is normally used for windows. Could this be a factor?
Users browsing this forum: No registered users and 46 guests
