 Post subject: Data Recovery stuck at 33,3%
PostPosted: September 26th, 2010, 1:12
So, I'm trying to recover some lost files. I put it on Data recovery 3. Everything went fine until the power in my house went out, stopping the entire process. NOW when I try to run the process, it just stalls at 33,3%, with no indication of how much time left...
Any help?
 Post subject: Re: Data Recovery stuck at 33,3%
PostPosted: September 26th, 2010, 6:54
What are you using to recover?
Maybe bad blocks developed on the drive, and your software can't pass them.
ACELab partner
PostPosted: September 26th, 2010, 10:27
My crystal ball says if you press this there, then it will be it
PostPosted: September 26th, 2010, 10:34
Don't worry and don't panic: some destructive solution will be delivered very soon 8)
Oh, even moving the dish, my BlackBall give confused images... Maybe adding manually some details...
PostPosted: September 26th, 2010, 11:47
How do I mend this?
Strangest thing, the demo version claims it can't find any files, while the full version just skips immedialty to 33,3% then freezes there. Dont understand, it was all fine until the power shortage.
It also calls it Bus: USB, is that a bad sign?
PostPosted: September 26th, 2010, 12:38
Still didn't give us more details..
Software you're using, etc...
ACELab partner
PostPosted: September 26th, 2010, 13:55
Sorry.
Here's the (sad) lowdown:
I tried Data Rescue 3. First it found the disk, then it analyzed it with good results. THEN a power shortage, and now it cant even analyze it.
Today I tried DiskWarrior which doesn't even FIND the disk, which is strange since it DOES appear in DiscUtility...
PostPosted: September 26th, 2010, 14:07
I'm sorry to hear that the drive is no longer recognized in the computer... This sounded a really cheap recovery work at first but now, it may cost a lot of money!!!
Not to be mean, but this is the result of DIY. Professionals have CLEAN POWER at their lab with expensive tools to avoid such failure.
More over, professionals use special tools to avoid such stuck.
If your data is important, you might want to take it to your local data recovery specialist or there are a few reputable guys on here from your area!!! Check with them!!!!
PostPosted: September 26th, 2010, 15:16
If the disk isn't found, how can your recover the files!?!?
Is it recognized in BIOS or not?
After being recognized, and if no noises, try R-studio to see what you can retrieve.
ACELab partner
PostPosted: September 26th, 2010, 15:46
As I say, it is recognized in DiscUtility (I use mac, so no "BIOS")
What is R-Studio?
PostPosted: September 26th, 2010, 16:03
AnrBjotk wrote:
pclab wrote:
What is R-Studio?
http://www.r-studio.com/
ACELab partner
PostPosted: September 26th, 2010, 17:01
Download SMART Utility - http://www.volitans-software.com/smart_utility.php
Install it and provide list of attributes from the drive you are trying to recover
Here is an example
It will tell your drive conditions
PostPosted: September 26th, 2010, 20:11
Here is an example
SmartUtility doesn't seem to find it either. Which is weird, since it STILL appears in DiscUtility. Can I somehow try to locate the disk manually in SmartUtility?
PostPosted: October 1st, 2010, 5:17
Can anyone help?
PostPosted: October 1st, 2010, 7:36
Sorry but my crystal ball has gone all cloudy again.....can't see a thing!
Can anybody see through all the mist and tell us what make, model, firmware etc the unknown device details? :lol: Any pro clairvoyants out there in Scandanavia?
PostPosted: October 1st, 2010, 10:54
Hi, sorry to hear that things have gone from bad to worse.
If you care aboute the data on the drive, don't play with it anymore.
I'm in Gothenburg/Sweden, if you want some help please contact me on PM.
Regards/ Bosse
http://www.rescue-it.se
Users browsing this forum: No registered users and 310 guests
