 Post subject: WD6401AALS failure
PostPosted: September 25th, 2010, 11:52
Hello.
Greetings from Poland Smile
Year and a half I am in possession of hard disk WD6401AALS. A few days ago, during normal operation, the computer crashed. After reboot, the BIOS does not recognize the disc. You can hear that the plates are spinning and the electronics are no traces of burning. I would add that a few weeks ago I had the same situation, except that after several actuations of the situation returned to normal. Has anyone encountered this kind of situation? Is there any chance of recovery (eg by replacing the pcb with a smooth drive)?
The disk is still under warranty, but I fear that, after putting it in for repair, the data stored on it are lost.
Please help.
 Post subject: Re: WD6401AALS failure
PostPosted: September 27th, 2010, 10:33
Any ideas?
PostPosted: September 27th, 2010, 10:44
now you can select one option: RMA the drive (bye bye data forever) < -- > move to recovery company who can help you
PostPosted: September 27th, 2010, 10:49
And what about the replacement pcb?
PostPosted: September 27th, 2010, 10:50
It won't solve your problem.
www.datarecoveryne.com
PostPosted: September 27th, 2010, 20:21
The replacement PCB might solve the problem - Put Hard Disk Sentinel (windows) on the computer. See what it says about the drive. If it says, "The drive controller is not supply information about the disk" etc. With a question mark, then replacing the PCB is likely to work - but it must be identical not to the DRIVE model, but to the PCB board model number.
If Hard Disk Sentinel can't even find the drive then you've got firmware issues, or some other anomaly. Either way, send it to a lab. PM me if you want a low cost recommendation.
PostPosted: September 28th, 2010, 1:46
PCB replacement won't do anything with dead heads/preamp/damaged SA
PostPosted: September 28th, 2010, 12:36
Yesterday, after dozens of trials starts, the drive suddenly revived. It happened after a few strokes with your finger, but the disk does not revived immediately after that, but only after next several attempts to start. The device worked half an hour, and just as suddenly revived, so was silent. Fortunately, it allowed me to rip the most valuable data. Tomorrow, the hard drive goes in for repair.
PostPosted: September 28th, 2010, 12:46
Ale masz szczescie stary! Hahaha
Nice one :D
Free Solutions
PostPosted: September 28th, 2010, 12:57
Cud normalnie :thankyou:
true true
Users browsing this forum: Google [Bot] and 110 guests
