 Post subject: Seagate 7200.4 st9500420as
PostPosted: September 23rd, 2010, 8:22
Hi forum
Does anyone know how to get terminal access on these drives
The drive is clicking 12 times and then remains bsy. It then continues to spin normally, drive will not show id
Any ideas will be greatly appreciated
Thank you
 Post subject: Re: Seagate 7200.4 st9500420as
PostPosted: September 23rd, 2010, 9:30
refer to my old stupid question here for terminal connection
pc3k-usb-terminal-question-t16313.html
i forgot to connect the power to the HDD
OR
use seagate sata adapter terminal cable + do not power on the drive now
then open ur HT set the speed/com ports correct
and power ON
u should see some log there if BR correct 38400
give it a shot
PostPosted: September 26th, 2010, 2:09
thx for reply
all items have bene connected correctly,with a working drive i am able to access terminal no issues,
the issue is that when the drive is remaining in BSY state i cant issue an commands in terminal, so i would like to access terminal mode to try and solve BSY issue on the drive.
i believe these drives have terminal locked during shipping.
thx
Users browsing this forum: Rendersmith and 101 guests
