 Post subject: Seagate and track 0 / partition table help please
PostPosted: September 26th, 2010, 20:08
I have a seagate 80 gb with an important information and it has a big problem with the track 0. I thought format the whole disk and then get the info again with easy recovery ontrack but my problem is that when I create a new partition the disk can not do it and if it gets it then the disk forgets it when I reset. I believe its a problem with the partition table in the track 0. I put my disk in other pc and you can not see the partitions those are lost.
I need help to repair my track 0 or some way to get my info
I had 2 partitions, the first was in fat32 and the second was in ntfs :(
seagate st3808110as
 Post subject: Re: Seagate and track 0 / partition table help please
PostPosted: September 26th, 2010, 22:02
If you have a problem such as yours, you must not format, partition, initialise, or do anything that writes on the drive.
Does your drive show up in BIOS with its correct model number and its full capacity?
Could we see the partition table and boot sector with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt.
PostPosted: September 27th, 2010, 5:49
The computer used for test the seagate disk has other 2 hdds so my report is long.
Date and time:
27/09/2010
15:34
0001.033
Sector Inspector Copyright Microsoft Corporation 2003
Target - \\.\PHYSICALDRIVE0
9729 Cylinders
255 Heads
63 Sectors Per Track
512 BytesPerSector
12 MediaType
Master Boot Record
| B | FS TYPE | START | END | | |
| F | (hex) | C H S| C H S| RELATIVE | TOTAL |
| * | 07 | 0 1 1|1023 254 63| 63| 156296322|
| | 00 | 0 0 0| 0 0 0| 0| 0|
Disk Signature 0x5e5a5e5a
Partition #1 NTFS backup boot sector at LBN 156296384.
LBN 0 [C 0, H 0, S 1]
0x0000 33 c0 8e d0 bc 00 7c fb-50 07 50 1f fc be 1b 7c 3ÀŽÐ¼.|ûP.Pü¾|
0x0010 bf 1b 06 50 57 b9 e5 01-f3 a4 cb bd be 07 b1 04 ¿.PW¹å.ó¤Ë½¾.±.
0x0020 38 6e 00 7c 09 75 13 83-c5 10 e2 f4 cd 18 8b f5 8n.|.uƒÅâôÍ‹õ
0x0030 83 c6 10 49 74 19 38 2c-74 f6 a0 b5 07 b4 07 8b ƒÆIt8,tö µ.´.‹
0x0040 f0 ac 3c 00 74 fc bb 07-00 b4 0e cd 10 eb f2 88 ð¬<.tü»..´.Íëòˆ
0x0050 4e 10 e8 46 00 73 2a fe-46 10 80 7e 04 0b 74 0b NèF.s*þF€~..t.
0x0060 80 7e 04 0c 74 05 a0 b6-07 75 d2 80 46 02 06 83 €~..t. ¶.uÒ€F..ƒ
0x0070 46 08 06 83 56 0a 00 e8-21 00 73 05 a0 b6 07 eb F..ƒV..è!.s. ¶.ë
0x0080 bc 81 3e fe 7d 55 aa 74-0b 80 7e 10 00 74 c8 a0 ¼>þ}Uªt.€~.tÈ
0x0090 b7 07 eb a9 8b fc 1e 57-8b f5 cb bf 05 00 8a 56 ·.ë©‹üW‹õË¿..ŠV
0x00a0 00 b4 08 cd 13 72 23 8a-c1 24 3f 98 8a de 8a fc .´.Ír#ŠÁ$?˜ŠÞŠü
0x00b0 43 f7 e3 8b d1 86 d6 b1-06 d2 ee 42 f7 e2 39 56 C÷ã‹Ñ†Ö±.ÒîB÷â9V
0x00c0 0a 77 23 72 05 39 46 08-73 1c b8 01 02 bb 00 7c .w#r.9F.s¸..».|
0x00d0 8b 4e 02 8b 56 00 cd 13-73 51 4f 74 4e 32 e4 8a ‹N.‹V.ÍsQOtN2äŠ
0x00e0 56 00 cd 13 eb e4 8a 56-00 60 bb aa 55 b4 41 cd V.ÍëäŠV.`»ªU´AÍ
0x00f0 13 72 36 81 fb 55 aa 75-30 f6 c1 01 74 2b 61 60 r6ûUªu0öÁ.t+a`
0x0100 6a 00 6a 00 ff 76 0a ff-76 08 6a 00 68 00 7c 6a j.j.ÿv.ÿv.j.h.|j
0x0110 01 6a 10 b4 42 8b f4 cd-13 61 61 73 0e 4f 74 0b .j´B‹ôÍaas.Ot.
0x0120 32 e4 8a 56 00 cd 13 eb-d6 61 f9 c3 54 61 62 6c 2äŠV.ÍëÖaùÃTabl
0x0130 61 20 64 65 20 70 61 72-74 69 63 69 a2 6e 20 6e a de partici¢n n
0x0140 6f 20 76 a0 6c 69 64 61-00 45 72 72 6f 72 20 61 o v lida.Error a
0x0150 6c 20 63 61 72 67 61 72-20 65 6c 20 73 69 73 74 l cargar el sist
0x0160 65 6d 61 20 6f 70 65 72-61 74 69 76 6f 00 46 61 ema operativo.Fa
0x0170 6c 74 61 20 65 6c 20 73-69 73 74 65 6d 61 20 6f lta el sistema o
0x0180 70 65 72 61 74 69 76 6f-00 00 00 00 00 00 00 00 perativo........
0x0190 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 2c 49 6e-5a 5e 5a 5e 00 00 80 01 .....,InZ^Z^..€.
0x01c0 01 00 07 fe ff ff 3f 00-00 00 82 e4 50 09 00 00 ...þÿÿ?...‚äP...
0x01d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 55 aa ..............Uª
Primary Partition 1
NTFS BIOS Parameter Block Information
BytesPerSector : 512
Sectors Per Cluster : 8
ReservedSectors : 0
Fats : 0
RootEntries : 0
Small Sectors : 0 ( 0 MB )
Media Type : 248 ( 0xf8 )
SectorsPerFat : 0
SectorsPerTrack : 63
Heads : 255
Hidden Sectors : 63
Large Sectors : 0 ( 0 MB )
ClustersPerFRS : 246
Clust/IndxAllocBuf : 1
NumberSectors : 156296321 ( 76316.6 MB )
MftStartLcn : 786432
Mft2StartLcn : 9768520
SerialNumber : 11022586029459075756
Checksum : 0 (0x0)
LBN 63 [C 0, H 1, S 1]
0x0000 eb 52 90 4e 54 46 53 20-20 20 20 00 02 08 00 00 ëRNTFS .....
0x0010 00 00 00 00 00 f8 00 00-3f 00 ff 00 3f 00 00 00 .....ø..?.ÿ.?...
0x0020 00 00 00 00 80 00 80 00-81 e4 50 09 00 00 00 00 ....€.€.äP.....
0x0030 00 00 0c 00 00 00 00 00-48 0e 95 00 00 00 00 00 ........H.•.....
0x0040 f6 00 00 00 01 00 00 00-ac 72 17 f8 97 17 f8 98 ö.......¬rø—ø˜
0x0050 00 00 00 00 fa 33 c0 8e-d0 bc 00 7c fb b8 c0 07 ....ú3ÀŽÐ¼.|û¸À.
0x0060 8e d8 e8 16 00 b8 00 0d-8e c0 33 db c6 06 0e 00 ŽØè.¸..ŽÀ3ÛÆ...
0x0070 10 e8 53 00 68 00 0d 68-6a 02 cb 8a 16 24 00 b4 èS.h..hj.ËŠ$.´
0x0080 08 cd 13 73 05 b9 ff ff-8a f1 66 0f b6 c6 40 66 .Ís.¹ÿÿŠñf.¶Æ@f
0x0090 0f b6 d1 80 e2 3f f7 e2-86 cd c0 ed 06 41 66 0f .¶Ñ€â?÷â†ÍÀí.Af.
0x00a0 b7 c9 66 f7 e1 66 a3 20-00 c3 b4 41 bb aa 55 8a ·Éf÷áf£ .ôA»ªUŠ
0x00b0 16 24 00 cd 13 72 0f 81-fb 55 aa 75 09 f6 c1 01 $.Ír.ûUªu.öÁ.
0x00c0 74 04 fe 06 14 00 c3 66-60 1e 06 66 a1 10 00 66 t.þ..Ãf`.f¡.f
0x00d0 03 06 1c 00 66 3b 06 20-00 0f 82 3a 00 1e 66 6a ...f;. ..‚:.fj
0x00e0 00 66 50 06 53 66 68 10-00 01 00 80 3e 14 00 00 .fP.Sfh...€>..
0x00f0 0f 85 0c 00 e8 b3 ff 80-3e 14 00 00 0f 84 61 00 .…..è³ÿ€>...„a.
0x0100 b4 42 8a 16 24 00 16 1f-8b f4 cd 13 66 58 5b 07 ´BŠ$.‹ôÍfX[.
0x0110 66 58 66 58 1f eb 2d 66-33 d2 66 0f b7 0e 18 00 fXfXë-f3Òf.·..
0x0120 66 f7 f1 fe c2 8a ca 66-8b d0 66 c1 ea 10 f7 36 f÷ñþŠÊf‹ÐfÁê÷6
0x0130 1a 00 86 d6 8a 16 24 00-8a e8 c0 e4 06 0a cc b8 .†ÖŠ$.ŠèÀä..̸
0x0140 01 02 cd 13 0f 82 19 00-8c c0 05 20 00 8e c0 66 ..Í.‚.ŒÀ. .ŽÀf
0x0150 ff 06 10 00 ff 0e 0e 00-0f 85 6f ff 07 1f 66 61 ÿ..ÿ....…oÿ.fa
0x0160 c3 a0 f8 01 e8 09 00 a0-fb 01 e8 03 00 fb eb fe àø.è.. û.è..ûëþ
0x0170 b4 01 8b f0 ac 3c 00 74-09 b4 0e bb 07 00 cd 10 ´.‹ð¬<.t.´.»..Í
0x0180 eb f2 c3 0d 0a 45 72 72-6f 72 20 64 65 20 6c 65 ëòÃ..Error de le
0x0190 63 74 75 72 61 20 64 65-20 64 69 73 63 6f 00 0d ctura de disco..
0x01a0 0a 46 61 6c 74 61 20 4e-54 4c 44 52 00 0d 0a 4e .Falta NTLDR...N
0x01b0 54 4c 44 52 20 63 6f 6d-70 72 69 6d 69 64 6f 00 TLDR comprimido.
0x01c0 0d 0a 50 72 65 73 69 6f-6e 65 20 43 74 72 6c 2b ..Presione Ctrl+
0x01d0 41 6c 74 2b 53 75 70 72-20 70 61 72 61 20 72 65 Alt+Supr para re
0x01e0 69 6e 69 63 69 61 72 0d-0a 00 00 00 00 00 00 00 iniciar.........
0x01f0 00 00 00 00 00 00 00 00-83 9f ad c0 00 00 55 aa ........ƒŸ­À..Uª
Target - \\.\PHYSICALDRIVE1
9729 Cylinders
255 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
| * | 85 | 0 65 0| 133 192 15| 596| 956843403|
| | 00 | 256 184 1| 199 116 54| 1879319620| 2298478658|
| | 14 | 807 36 40| 133 0 0| 965021632| 2332033027|
| | 42 | 640 8 33| 199 0 0| 4360197| 4294967040|
Disk Signature 0x00026d8e
0x0120 32 e4 8a 56 00 cd 13 eb-d6 61 f9 c3 49 6e 76 61 2äŠV.ÍëÖaùÃInva
0x0130 6c 69 64 20 70 61 72 74-69 74 69 6f 6e 20 74 61 lid partition ta
0x0140 62 6c 65 00 45 72 72 6f-72 20 6c 6f 61 64 69 6e ble.Error loadin
0x0150 67 20 6f 70 65 72 61 74-69 6e 67 20 73 79 73 74 g operating syst
0x0160 65 6d 00 4d 69 73 73 69-6e 67 20 6f 70 65 72 61 em.Missing opera
0x0170 74 69 6e 67 20 73 79 73-74 65 6d 00 00 00 00 00 ting system.....
0x0180 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 75 10 85 d2 89 4d e8 0f-8e 6d 02 00 00 a1 c0 41 u…Ò‰Mè.Žm...¡ÀA
0x01c0 00 00 85 c0 0f 85 54 02-00 00 8b 45 08 39 05 b8 ..…À.…T...‹E.9.¸
0x01d0 41 00 00 74 36 c7 44 24-04 70 42 00 00 89 04 24 A..t6ÇD$.pB..‰.$
0x01e0 e8 27 14 00 00 85 c0 0f-85 39 03 00 00 8b 55 08 è'..…À.…9...‹U.
0x01f0 a1 80 42 00 00 c7 05 88-42 00 00 ff ff ff ff 0f ¡€B..Ç.ˆB..ÿÿÿÿ.
Primary Partition 1
LBN 596 [C 0, H 9, S 30]
0x0000 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0010 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0030 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0040 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0050 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0060 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0070 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0080 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0090 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00d0 03 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0100 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0110 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0120 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0130 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0140 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0150 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0160 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0170 08 00 01 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 00 00 00-00 00 40 00 20 00 00 00 ..........@. ...
0x01c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
Error 27 was encountered reading from \\.\PHYSICALDRIVE1.
La unidad no puede hallar el sector requerido.
Target - \\.\PHYSICALDRIVE2
30401 Cylinders
255 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
| * | 0c |1023 254 63|1023 254 63| 29623860| 32772600|
| | 07 |1023 254 63|1023 254 63| 62396460| 102398310|
| | 0f |1023 254 63|1023 254 63| 164794770| 323597295|
Disk Signature 0xa3f9a3f9
Partition #2 NTFS backup boot sector at LBN 164794769.
0x01b0 00 00 00 00 00 2c 49 6e-f9 a3 f9 a3 00 00 80 fe .....,Inù£ù£..€þ
0x01c0 ff ff 0c fe ff ff 34 06-c4 01 f8 11 f4 01 00 fe ÿÿ.þÿÿ4.Ä.øô..þ
0x01d0 ff ff 07 fe ff ff 2c 18-b8 03 66 79 1a 06 00 fe ÿÿ.þÿÿ,¸.fy..þ
0x01e0 ff ff 0f fe ff ff 92 91-d2 09 ef b3 49 13 00 00 ÿÿ.þÿÿ’‘Ò.ï³I..
Primary Partition 1
FAT32 BIOS Parameter Block Information
Sectors Per Cluster : 16
ReservedSectors : 34
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 29623860
Large Sectors : 32772600 ( 16002 MB )
LargeSectorsPerFat : 15987
ExtendedFlags : 0
FsVersion : 0
RootDirFirstCluster : 2
FsInfoSector : 1
BackupBootSector : 6
Label :
LBN 29623860 [C 1844, H 0, S 1]
0x0000 eb 58 90 4d 53 44 4f 53-35 2e 30 00 02 10 22 00 ëXMSDOS5.0..".
0x0010 02 00 00 00 00 f8 00 00-3f 00 ff 00 34 06 c4 01 .....ø..?.ÿ.4.Ä.
0x0020 f8 11 f4 01 73 3e 00 00-00 00 00 00 02 00 00 00 øô.s>..........
0x0030 01 00 06 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0040 80 00 29 fc d5 19 cc 4e-4f 20 4e 41 4d 45 20 20 €.)üÕÌNO NAME
0x0050 20 20 46 41 54 33 32 20-20 20 33 c9 8e d1 bc f4 FAT32 3ɎѼô
0x0060 7b 8e c1 8e d9 bd 00 7c-88 4e 02 8a 56 40 b4 08 {ŽÁŽÙ½.|ˆN.ŠV@´.
0x0070 cd 13 73 05 b9 ff ff 8a-f1 66 0f b6 c6 40 66 0f Ís.¹ÿÿŠñf.¶Æ@f.
0x0080 b6 d1 80 e2 3f f7 e2 86-cd c0 ed 06 41 66 0f b7 ¶Ñ€â?÷â†ÍÀí.Af.·
0x0090 c9 66 f7 e1 66 89 46 f8-83 7e 16 00 75 38 83 7e Éf÷áf‰Føƒ~.u8ƒ~
0x00a0 2a 00 77 32 66 8b 46 1c-66 83 c0 0c bb 00 80 b9 *.w2f‹FfƒÀ.».€¹
0x00b0 01 00 e8 2b 00 e9 48 03-a0 fa 7d b4 7d 8b f0 ac ..è+.éH. ú}´}‹ð¬
0x00c0 84 c0 74 17 3c ff 74 09-b4 0e bb 07 00 cd 10 eb „Àt<ÿt.´.»..Íë
0x00d0 ee a0 fb 7d eb e5 a0 f9-7d eb e0 98 cd 16 cd 19 î û}ëå ù}ëà˜ÍÍ
0x00e0 66 60 66 3b 46 f8 0f 82-4a 00 66 6a 00 66 50 06 f`f;Fø.‚J.fj.fP.
0x00f0 53 66 68 10 00 01 00 80-7e 02 00 0f 85 20 00 b4 Sfh...€~...… .´
0x0100 41 bb aa 55 8a 56 40 cd-13 0f 82 1c 00 81 fb 55 A»ªUŠV@Í.‚.ûU
0x0110 aa 0f 85 14 00 f6 c1 01-0f 84 0d 00 fe 46 02 b4 ª.….öÁ..„..þF.´
0x0120 42 8a 56 40 8b f4 cd 13-b0 f9 66 58 66 58 66 58 BŠV@‹ôͰùfXfXfX
0x0130 66 58 eb 2a 66 33 d2 66-0f b7 4e 18 66 f7 f1 fe fXë*f3Òf.·Nf÷ñþ
0x0140 c2 8a ca 66 8b d0 66 c1-ea 10 f7 76 1a 86 d6 8a ŠÊf‹ÐfÁê÷v†ÖŠ
0x0150 56 40 8a e8 c0 e4 06 0a-cc b8 01 02 cd 13 66 61 V@ŠèÀä..̸..Ífa
0x0160 0f 82 54 ff 81 c3 00 02-66 40 49 0f 85 71 ff c3 .‚TÿÃ..f@I.…qÿÃ
0x0170 4e 54 4c 44 52 20 20 20-20 20 20 00 00 00 00 00 NTLDR .....
0x01a0 00 00 00 00 00 00 00 00-00 00 00 00 0d 0a 46 61 ..............Fa
0x01b0 6c 74 61 20 4e 54 4c 44-52 ff 0d 0a 45 72 72 6f lta NTLDRÿ..Erro
0x01c0 72 20 64 65 20 64 69 73-63 6f ff 0d 0a 50 72 65 r de discoÿ..Pre
0x01d0 73 2e 20 75 6e 61 20 74-65 63 6c 61 0d 0a 00 72 s. una tecla...r
0x01e0 65 73 74 61 72 74 0d 0a-00 00 00 00 00 00 00 00 estart..........
0x01f0 00 00 00 00 00 00 00 00-00 ac ba cb 00 00 55 aa .........¬ºË..Uª
Primary Partition 2
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 62396460
NumberSectors : 102398309 ( 49999.2 MB )
Mft2StartLcn : 6399894
SerialNumber : 7103356652819125455
Checksum : 0 (0x0)
LBN 62396460 [C 3884, H 0, S 1]
0x0010 00 00 00 00 00 f8 00 00-3f 00 ff 00 2c 18 b8 03 .....ø..?.ÿ.,¸.
0x0020 00 00 00 00 80 00 80 00-65 79 1a 06 00 00 00 00 ....€.€.ey.....
0x0030 00 00 0c 00 00 00 00 00-96 a7 61 00 00 00 00 00 ........–§a.....
0x0040 f6 00 00 00 01 00 00 00-cf 14 31 94 3d 31 94 62 ö.......Ï1”=1”b
0x01c0 0d 0a 43 74 72 6c 2b 41-6c 74 2b 53 75 70 72 20 ..Ctrl+Alt+Supr
0x01d0 70 61 72 61 20 72 65 69-6e 69 63 69 61 72 0d 0a para reiniciar..
0x01e0 00 72 65 73 74 61 72 74-0d 0a 00 00 00 00 00 00 .restart........
Extended Boot Record
| | 07 |1023 254 63|1023 254 63| 63| 165887127|
| | 05 |1023 254 63|1023 254 63| 165887190| 157694040|
Partition #1 NTFS backup boot sector at LBN 330681959.
LBN 164794770 [C 10258, H 0, S 1]
0x00d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0170 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 fe ...............þ
0x01c0 ff ff 07 fe ff ff 3f 00-00 00 97 3c e3 09 00 fe ÿÿ.þÿÿ?...—<ã..þ
0x01d0 ff ff 05 fe ff ff d6 3c-e3 09 58 38 66 09 00 00 ÿÿ.þÿÿÖ<ã.X8f...
Logical Volume
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
NumberSectors : 165887126 ( 80999.6 MB )
Mft2StartLcn : 10367945
SerialNumber : 13999487971727513893
Checksum : 0 (0x0)
LBN 164794833 [C 10258, H 1, S 1]
0x0020 00 00 00 00 80 00 80 00-96 3c e3 09 00 00 00 00 ....€.€.–<ã.....
0x0030 00 00 0c 00 00 00 00 00-c9 33 9e 00 00 00 00 00 ........É3ž.....
0x0040 f6 00 00 00 01 00 00 00-25 19 2c 48 23 2c 48 c2 ö.......%,H#,HÂ
| | 07 |1023 254 63|1023 254 63| 63| 157693977|
Partition #1 NTFS backup boot sector at LBN 488375999.
LBN 330681960 [C 20584, H 0, S 1]
0x01c0 ff ff 07 fe ff ff 3f 00-00 00 19 38 66 09 00 00 ÿÿ.þÿÿ?...8f...
Logical Volume
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
NumberSectors : 157693976 ( 76999 MB )
Mft2StartLcn : 9855873
SerialNumber : 2078499978569879742
Checksum : 0 (0x0)
LBN 330682023 [C 20584, H 1, S 1]
0x0020 00 00 00 00 80 00 80 00-18 38 66 09 00 00 00 00 ....€.€.8f.....
0x0030 00 00 0c 00 00 00 00 00-81 63 96 00 00 00 00 00 ........c–.....
0x0040 f6 00 00 00 01 00 00 00-be 90 50 d8 b7 50 d8 1c ö.......¾PØ·PØ
Date and time:
27/09/2010
15:37
0001.033
9729 Cylinders
255 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
Checksum : 0 (0x0)
9729 Cylinders
255 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
| * | 00 | 833 21 8| 640 0 33| 687865922| 2312649155|
| * | 4c | 905 114 25| 199 36 8| 271428| 2298478592|
| | c8 | 789 36 63| 0 65 0| 136608905| 2314227083|
| | 45 | 139 36 4| 516 24 9| 4211468324| 2099904511|
Disk Signature 0x89000200
0x0040 00 00 00 00 00 00 00 00-80 02 00 00 00 00 00 00 ........€.......
0x0050 00 00 00 00 00 00 00 00-00 00 00 00 00 40 00 00 .............@..
0x0090 00 00 00 00 00 00 20 00-00 00 00 00 00 00 00 00 ...... .........
0x00a0 00 00 00 00 00 00 00 00-50 00 00 00 00 00 00 00 ........P.......
0x00b0 00 00 00 20 40 00 00 00-00 00 00 00 00 00 00 00 ... @...........
0x0160 00 00 00 00 00 00 00 00-00 00 00 00 00 40 01 00 .............@..
0x01b0 8d 72 01 c7 04 24 04 00-00 02 00 89 14 24 ff 15 r.Ç.$.....‰$ÿ
0x01c0 c8 41 00 00 a1 80 42 00-00 29 c3 39 d8 89 d9 72 ÈA..¡€B..)Ã9؉Ùr
0x01d0 d9 89 4c 24 08 c7 44 24-04 00 00 00 00 89 34 24 Ù‰L$.ÇD$.....‰4$
0x01e0 ff 15 c8 41 00 00 89 7c-24 08 8b 4d f0 89 4c 24 ÿÈA..‰|$.‹Mð‰L$
0x01f0 04 8b 45 18 89 04 24 e8-05 fb ff ff 29 7d 14 8b .‹E‰.$è.ûÿÿ)}‹
Primary Partition 2
LBN 271428 [C 16, H 228, S 25]
0x0000 6d fc 06 f1 a0 bf 1b 34-bb b2 3e 85 1d b6 c7 56 mü.ñ ¿4»²>…¶ÇV
0x0010 c0 c3 8b d8 c6 d0 f6 67-f8 1b d0 db 21 f4 4c 64 ÀÃ‹ØÆÐögøÐÛ!ôLd
0x0020 b0 ba 91 b5 52 8b b3 27-a5 d3 ee e3 1a 03 31 c1 °º‘µR‹³'¥Óîã.1Á
0x0030 52 87 f7 7c be 8c eb d8-6f 57 ea dc c1 37 c8 ca R‡÷|¾ŒëØoWêÜÁ7ÈÊ
0x0040 a3 a7 c0 b3 ba ad 37 5b-ad 3e 52 9b c5 79 cb a2 £§À³º­7[­>R›ÅyË¢
0x0050 c9 c4 60 18 a8 d7 dc dd-66 26 e9 29 9b 4c 6e e6 ÉÄ`¨×ÜÝf&é)›Lnæ
0x0060 4b 64 0d fd a9 d3 8d ac-3d aa 57 36 db 74 91 1d Kd.ý©Ó¬=ªW6Ût‘
0x0070 25 e5 b7 9d c8 76 82 a8-24 d9 c6 24 6b d7 2a 90 %川Èv‚¨$ÙÆ$k×*
0x0080 3b b6 49 70 71 b5 7c 65-3a 63 6c b6 15 44 2d f8 ;¶Ipqµ|e:cl¶D-ø
0x0090 0f 8a fd 33 9b f7 19 dc-b9 ae de 08 1b 70 9a ed .Šý3›÷ܹ®Þ.pší
0x00a0 b3 bc 15 9a 2f 0b d0 0c-4b 9d 3a 8a 9d b9 0a e7 ³¼š/.Ð.K:Š¹.ç
0x00b0 a3 62 23 41 28 5b 10 81-b1 31 6f d3 18 1e dc aa £b#A([±1oÓܪ
0x00c0 4c 25 83 06 48 77 99 7e-e4 2d 2e 13 84 ec 46 65 L%ƒ.Hw™~ä-.„ìFe
0x00d0 d6 54 fa 5d 4b 37 e1 df-49 67 72 17 c6 32 d6 97 ÖTú]K7áßIgrÆ2Ö—
0x00e0 58 05 be 70 69 8c 0e 9f-99 ae 80 ba 21 c3 3b 27 X.¾piŒ.Ÿ™®€º!Ã;'
0x00f0 65 45 45 fa 75 37 80 1b-57 2b 97 96 32 c6 89 d7 eEEúu7€W+—–2Ɖ×
0x0100 75 3c 4d 4d 63 f3 6d 06-70 a2 03 88 51 35 4e 8e u<MMcóm.p¢.ˆQ5NŽ
0x0110 23 a6 9d 72 09 09 2f 04-ee 2d d2 16 d5 da df 8a #¦r../.î-ÒÕÚߊ
0x0120 67 49 4b d0 fb e5 44 2d-68 4a fb a7 2b f7 2d c0 gIKÐûåD-hJû§+÷-À
0x0130 f8 66 c3 3f e1 68 6f 05-fc ec d7 fc c6 d8 75 2d øfÃ?áho.üì×üÆØu-
0x0140 88 13 a3 c7 08 8f 85 ad-c3 f5 5f 42 55 c7 f8 e1 ˆ£Ç.…­Ãõ_BUÇøá
0x0150 35 b8 93 c2 4a 87 60 22-1b e2 67 0a 0c e1 c2 cb 5¸“ÂJ‡`"âg..áÂË
0x0160 17 cd 0a b0 a4 58 51 0b-17 80 41 2e fb 22 50 25 Í.°¤XQ.€A.û"P%
0x0170 8f eb 1c bf 73 5b c7 66-39 46 e6 2a cc e3 44 71 ë¿s[Çf9Fæ*ÌãDq
0x0180 90 cb 35 5b 1b fc f1 83-a2 1c 58 d1 7c 24 67 41 Ë5[üñƒ¢XÑ|$gA
0x0190 0f 04 f8 e6 f5 77 1b b1-d9 af 27 79 c9 3c 5d aa ..øæõw±Ù¯'yÉ<]ª
0x01a0 5c 34 72 fa 3f fc 44 fd-2b cd f3 15 6b 64 88 39 \4rú?üDý+Íókdˆ9
0x01b0 ad 9a 45 1a f1 de 5f 9d-63 e6 49 68 68 ed 61 07 ­šEñÞ_cæIhhía.
0x01c0 fd 0c 36 d0 92 ac e4 7c-04 0a 3a 85 db de 27 ce ý.6Ð’¬ä|..:…ÛÞ'Î
0x01d0 5a f6 08 ca fd 0d 4f 91-70 85 5b 82 2a 63 0c d0 Zö.Êý.O‘p…[‚*c.Ð
0x01e0 8f 86 96 7a 86 c9 90 7e-f5 00 6d f8 a9 8f ef f5 †–z†É~õ.mø©ïõ
0x01f0 dd e2 fe 7b 0f 5a f9 c2-3e 73 7e 09 d8 1d 9f 34 Ýâþ{.ZùÂ>s~.ØŸ4
Primary Partition 3
LBN 136608905 [C 8503, H 130, S 21]
0x0000 01 c4 6f f7 fa 7d 60 d7-5f 97 8d 24 cf e0 55 5b .Äo÷ú}`×_—$ÏàU[
0x0010 e3 ba 61 27 29 e0 0b 2f-b4 c6 24 d7 e0 0f f7 57 ãºa')à./´Æ$×à.÷W
0x0020 ba 44 4f e0 dc fb 69 6e-80 0d 17 e0 a0 ab fd bf ºDOàÜûin€.à «ý¿
0x0030 04 3f e4 6b 7e 8f ef 49-29 63 10 eb ea c3 ad 8b .?äk~ïI)cëêí‹
0x0040 31 84 10 fa 5d ab 00 80-26 1f e0 2b 0b 27 8c 80 1„ú]«.€&à+.'Œ€
0x0050 0f b7 26 07 28 4e 20 bf-e1 9f bf fa 8a 31 c5 18 .·&.(N ¿áŸ¿úŠ1Å
0x0060 e0 81 d5 87 ef 6d 62 80-c6 ef ba 0d 2b e0 e2 2c àÕ‡ïmb€Æïº.+àâ,
0x0070 36 fe 80 11 c7 e0 b4 bc-a2 bf 80 09 bf e2 f0 c8 6þ€Çà´¼¢¿€.¿âðÈ
0x0080 70 40 e9 20 22 08 ae de-df 36 80 11 77 e0 2e 82 p@é ".®Þß6€wà.‚
0x0090 fb ed 80 1d 7f e0 2a 2a-bb 5b 80 29 af e2 6b 82 ûí€à**»[€)¯âk‚
0x00a0 aa ab 08 21 84 10 c8 7c-f8 ba 80 15 e7 e0 8a 0e ª«.!„È|øº€çàŠ.
0x00b0 2a 27 80 33 07 e0 70 28-fb ae 64 67 c3 50 ef 00 *'€3.àp(û®dgÃPï.
0x00c0 fe 1c 9a e0 af 74 fe 75-04 9f e0 ab 8a aa 6b 21 þšà¯tþu.Ÿà«Šªk!
0x00d0 bf 4a e0 00 80 88 8d 80-19 f7 e0 62 83 9b bb 24 ¿Jà.€ˆ€÷àbƒ›»$
0x00e0 a7 e0 f2 f2 e8 7d 04 df-e0 6a 0a a3 8a 04 77 e0 §àòòè}.ßàj.£Š.wà
0x00f0 29 2e b8 ea 01 3f 69 e0-2b bb af ad 41 07 aa 63 ).¸ê.?ià+»¯­A.ªc
0x0100 17 2a 0b 0b e2 69 29 5e-b0 06 07 eb 57 81 cc a7 *..âi)^°..ëWÌ§
0x0110 98 26 ae e0 20 2e ae 75-00 07 e0 31 8b c8 ff 09 ˜&®à .®u..à1‹Èÿ.
0x0120 1f 7d 07 07 bd 35 3f e0-fa 7c 58 3a 80 16 bf e0 }..½5?àú|X:€¿à
0x0130 17 b0 0a 84 64 a7 63 77-49 aa ae e0 c7 18 be 34 °.„d§cwIª®àǾ4
0x0140 80 84 f7 af 3a e0 5e d7-df ca 81 2f 45 07 97 9f €„÷¯:à^×ßʁ/E.—Ÿ
0x0150 fc db e0 bf f9 af 8a 80-14 9f e0 b8 3e a7 e5 64 üÛà¿ù¯Š€Ÿà¸>§åd
0x0160 1f e0 fe e2 ea fd 24 67-e0 27 ae ab bb 04 2f e0 àþâêý$gà'®«»./à
0x0170 b0 5a 62 c8 80 04 4f e0-25 a5 ad ae 04 4f e0 ad °ZbÈ€.Oà%¥­®.Oà­
0x0180 ed cb ea 68 ff 80 c4 1f-0d a5 3b e0 78 e6 ea ff íËêhÿ€Ä.¥;àxæêÿ
0x0190 80 16 7f e0 08 aa 8e e9-61 87 08 e1 e0 60 78 7f €à.ªŽéa‡.áà`x
0x01a0 ab 39 23 00 81 c7 ff ad-2d 0d e0 73 6b 7d 63 24 «9#.Çÿ­-.àsk}c$
0x01b0 98 80 09 5e e0 ca f8 9f-f6 04 47 e0 63 62 ee ff ˜€.^àÊøŸö.Gàcbîÿ
0x01c0 81 18 8f e1 a2 da e8 4a-29 22 08 aa 80 c6 67 9e á¢ÚèJ)".ª€Ægž
0x01d0 fa f3 e0 29 89 ff e6 80-0e a7 e0 f6 37 2e db 44 úóà)‰ÿæ€.§àö7.ÛD
0x01e0 47 e0 2f 1c 9c bc 01 5f-6b c1 af 4f be 9c e0 21 Gà/œ¼._kÁ¯O¾œà!
0x01f0 ff f7 8b 80 49 0f df e2-7f 8f 0f ca 8b 31 e6 18 ÿ÷‹€I.ßâ.Ê‹1æ
30401 Cylinders
255 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
PostPosted: September 27th, 2010, 5:50
Primary Partition 1
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 255
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
Primary Partition 2
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Checksum : 0 (0x0)
0x0160 c3 a0 f8 01 e8 09 00 a0-fb 01 e8 03 00 fb eb fe à ø.è.. û.è..ûëþ
Logical Volume
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
Checksum : 0 (0x0)
Logical Volume
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
Checksum : 0 (0x0)
PostPosted: September 27th, 2010, 6:14
I tried of use the program in other pc with windows 7 but it does not allow to access so I brought the long report.
PostPosted: September 27th, 2010, 6:30
It appears that PHYSICALDRIVE1 has a corrupted partition table. My approach would be to zero out the nonsensical entries, and then use a partition recovery utility to rebuild the partition table.
Change LBN 0 of PHYSICALDRIVE1 from this ...
... to this:
0x01b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 55 aa ................
You can use a disc editor such as HxD to edit the MBR.
Select Extras -> Open Disk, uncheck the Readonly box, and select your appropriate Physical Disk. In the Sector box type 0 and hit Enter. That's LBA 0.
LBA 63 would the boot sector of the first partition. It should contain text strings such as NTFS or FAT32 depending on your file system.
After editing the MBR, you can use Testdisk or Partition Find and Mount to locate your partitions, assuming they are intact. However, you may like to upload the contents of sector 63 before you try this.
TestDisk:
http://www.cgsecurity.org/wiki/TestDisk
HxD - Freeware Hex Editor and Disk Editor:
http://mh-nexus.de/en/hxd/
Partition Find and Mount:
http://findandmount.com/
PostPosted: September 27th, 2010, 7:15
Before you do anything make a complete by sector cloned image of your drive! This can be either to a file on another drive or directly to a replacement/spare.
Then recover your 'important' data.
After you can follow any advice to repair/experiment/play with your drive.
PostPosted: September 27th, 2010, 7:30
Imaging the drive with 0 sector bad without special tools, is it possible ?
RAID/Server Recovery
PostPosted: September 27th, 2010, 16:11
Sector 0 appears to be logically corrupt, not physically bad. The MBR code is intact, but the partition table is jibberish.
That said, I'm having trouble understanding the OP's statement that "my problem is that when I create a new partition the disk can not do it and if it gets it then the disk forgets it when I reset".
PostPosted: September 27th, 2010, 16:22
I agree, but in this case I'm suggesting a targeted approach which should be perfectly safe. In any case, should the OP wish to restore the original data, there is a backup in this very thread.
PostPosted: October 18th, 2010, 12:00
Thank you very much for your replies :D
So the sector 0 must be filled with only 0 and ".........." in the second column and the same with LBA 63 (but 55aa in the end). And I don't have to edit anything exept those sectors.
I am going to try.
I meant when I tried to create a new partition windows xp failed several times and when windows got it the partition vanished after reset.
PostPosted: October 18th, 2010, 13:09
You should really stop what you are doing and make a clone of this disk. You drive your data and if it is as important as you say it is clone it and work from the clone. You can have a failing disk and keeping up what you are doing is only going to make it work and possible data loss on this one. You choice on this.
Iorana Haraharaini
PostPosted: October 18th, 2010, 13:45
Ok, ok. how do you make a clone from a hdd without partitions? what program do you recommend?
PostPosted: October 18th, 2010, 16:15
DDRescue will do the trick.
ACELab partner
PostPosted: October 18th, 2010, 16:19
After you clone the drive using ddrescue, I would try using testdisk to scan the drive and rebuild the partition table.
PostPosted: October 18th, 2010, 16:26
I am going to try.
Scarlet, you misunderstand me. I think it is better for you not to write anything to your drive. I suggest you follow poehere's advice and clone it with ddrescue.
Otherwise, if you can upload the contents of sector 63 of PHYSICALDRIVE1, then we will have a better idea of the damage. Whatever you do, do not edit this sector. My original idea was to use the information in sector 63, if intact, to rebuild sector 0.
PostPosted: November 3rd, 2010, 16:11
How can I clone a hdd with problems in the partition table?
I wanted clone my hdd with xxclone (I have windows xp so I can not use programs for Linux) but I couldn't because I can not select a source (partition) since the whole hdd is shown now like space without partition so if you know of another program working in a diferent way...
PostPosted: November 3rd, 2010, 18:20
You need to make a physical, sector-to-sector copy, not a logical clone. Then use data recovery software to reconstruct the partition table and file system(s) on the clone drive.
Try HDClone:
http://www.miray.de/products/sat.hdclone.html
Users browsing this forum: Google [Bot] and 214 guests
