 Post subject: ST3200822AS Not handled software path:
PostPosted: October 6th, 2010, 13:50
Trying to recover the hardware.
In the terminal:
4096k x 16 buffer detected
APLUS - 1_Disk S.07 08-10-04 16:37
Spin Ready
3.02 08-10-04 16:38
(P)SATA Reset
Mesa C3 Grand C Stuff Mesa 0A/95C7/954F Native mode
(S)SATA Reset
Mesa C3 Grand C Stuff Mesa 0A/9547/954F Native mode
In MHDD:
ERASE
In the terminal:
RE 43 at 00006040
CE Log EC=43 Rtype=41 OV=0 STStatus79
CE Log EC=0 Rtype=40 OV=0 STStatus79
RE 43 at 00007d1f
RE 43 at 000081ef
RE 43 at 00008ee0
In MHDD:
ERASE then completes and erases 390,721,968 LBA without further errors showing in the terminal.
Then in the terminal:
AT Er 00 Nwt Er 43 RdWr 04808.01.0000
ATA St 50 Er 00 Op 35 e, 1749f13a,7600 0000 0000
Niwot: 00019cc0 ff 00019cc0.0.000 8000 0ec0 0fe0 0000
CE Log EC=43 Rtype=26 OV=0 STStatus79
And in MHDD:
ID
Drive is not ready.
(Power ON/OFF)
SCAN
In the terminal:
AT Er 00 Nwt Er 47 RdWr 0263d.02.0000
ATA St d0 Er 10 Op 42 e, 2ded570,ff00 4900 0000
Niwot: 02d1143f 1a 02d1143f.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 47 RdWr 02787.02.0000
ATA St d0 Er 10 Op 42 e, 2f740ec,ff00 7200 0000
Niwot: 02ded66f 1a 02ded66f.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 47 RdWr 027c2.02.0000
ATA St d0 Er 10 Op 42 e, 2fbbf69,ff00 d300 0000
Niwot: 02f741eb 1a 02f741eb.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 43 RdWr 02818.02.0000
ATA St d0 Er 40 Op 42 e, 30270b1,ff00 f700 0000
Niwot: 02fbc068 1a 02fbc068.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 47 RdWr 028a0.01.0198
ATA St d0 Er 10 Op 42 e, 30c54c3,ff00 1500 0000
Niwot: 030271b0 1a 030271b0.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 43 RdWr 02911.02.0000
ATA St d0 Er 40 Op 42 e, 314a768,ff00 6600 0000
Niwot: 030c55c2 1a 030c55c2.0.000 8000 1200 033e 0000
AT Er 00 Nwt Er 47 RdWr 02933.01.0001
ATA St d0 Er 10 Op 42 e, 3178c80,ff00 6500 0000
Niwot: 0314a867 1a 0314a867.0.000 8000 1200 033e 0000
In MHDD:
Scanning the disk shows that over the entire disk, about 25 brown and red per screen, 15 green, and 4 or 5 S or x.
I take it that all this means that head or surface 0 is flaky, and there is a bad sector in the system tracks somewhere.
My question is, if I were to try to selfscan, what age do I set the drive to, and what is the proper command?
Do I use T># and enter the serial number, then run T>N2,,22 ? Or T>D1,,40 ?
Do I use T>w2 to write the CERT table when it finishes? Can the bad head be disabled if it cannot be recalibrated by the selfscan?
PM is OK.
http://www.youtube.com/user/TerraformingMaster
 Post subject: Re: ST3200822AS Not handled software path:
PostPosted: November 10th, 2012, 5:49
Hi.
You Better first fix By CE-LOG then Fix Bad Sectors, But in similar situation Sectors are not recoverable, So I tried Self Scan, whats tool u use?
PostPosted: November 10th, 2012, 5:52
Two years old post!
Users browsing this forum: Google [Bot] and 63 guests
