 Post subject: Recover from a Panasonic video carmera
PostPosted: October 8th, 2010, 14:53
Hi all,
I got a video carmera with built in 8GB flash memory.
It is a panasonic HDC-TM10 Full HD.
Someone accidently eras a video recording from the built in memory.
I succeed with R-studio to get some stils pictures out and alot of pcd files under the folder "Kodak PhotoCD Image".
How can I merge those file to a movie?
Is there any other option to recover the video which been deleted from that carmera?
I checked with winhex and saw that all the memory is ocupied with data.
Many Thanks!
 Post subject: Re: Recover from a Panasonic video carmera
PostPosted: October 8th, 2010, 16:53
I have used AVS video converter for merging moive files
PostPosted: October 11th, 2010, 6:19
Scorpion wrote:
Hi all,
Many Thanks!
i guess that r-studio will not do much here, well i have a recommendation here to u
try ZAR maybe 8.5 latest, try the demo ver. it has the feature of scanning mem. cards/cam
give it a shot, i was always happy with it.
PostPosted: October 11th, 2010, 6:26
You can also try and play the pieces of files in a program called VirtualDub - But it is Codec depended but you can use it to join and analyse files(if correct codecs are installed)
You can also try VLC- it has many built in codecs.
Free Solutions
PostPosted: October 12th, 2010, 6:22
Great spot I will certainly will give it a shut and update you all the progress. :D
Intersting.. if the ZAR won't do the job I will check this out. :)
Users browsing this forum: No registered users and 58 guests
