Good Quality USB RS232 adapter for Seagate Terminal Work
October 10th, 2010, 13:38
dear friends I need professional quality USB - RS232 adapters for seagate drives , pls. suggest me best available adapters and where to get them.
appreciate help with thanks
Re: Good Quality USB RS232 adapter for Seagate Terminal Work
October 10th, 2010, 17:31
you can find it here :mrgreen:
udma-for-seagate-for-400-the-chinese-way-t17305.html
October 11th, 2010, 3:51
zebong
I asked for RS-232 converter , & not to ditect to my own post.If you know the source post your comments or else............
Better Shut UP
October 11th, 2010, 5:04
You have a bad attitude, this will never help get what you want.
A little appreciation for others who take the time to read and respond would not be so bad.
I think too many people see this forum not as a discussion forum but a mandatory Q&A for DIY data recovery.
October 11th, 2010, 5:26
... or DIFM / DIFSE data recovery
(Do It For Money / Do It For Someone Else).
October 11th, 2010, 5:28
The problem is he asking strange questions.
What makes one RS-232 convertor better than the other? The plastic box it comes in?
They will do the same thing if you do it DIY for 5USD or buy one from a DIY Shop 25USD.
October 11th, 2010, 5:58
Must be the reason because many people with "el cheapo" stuff , possessed by DIY lust, have completely fucked up the interface ports of their invaluable drives ? :mrgreen:
October 11th, 2010, 6:13
learner wrote:zebong
Better Shut UP
bad attitude learner, well, if your nickname here means something which i guess not
u will find ignorance later for ur posts if ur going to act this way.
good luck
October 11th, 2010, 6:55
only BlackST has understood what I mean in this post , if you check market there are so many chipset manufacturers like silicon labs etc. My post was to know from those peoples who are using tools of the trade everyday and can better guide right solution.
pls. note my posts are never arrogant and insultive ,but if someone is intensionally harassing you ,is it ok to be quiet and accept your own insult for no reason? I can understand rules of the forum and one can check in not a single post I had tried to make someone inferior. "
"The problem is he asking strange questions.
like this post by ppumkin ,instead of wasting so many lines he can simply direct me to sellers site or if he did not understood my question better not comment.
hope everyone will understood
I am sorry if I have inadverently hurt someone which wasn't my intention.It was a natural and justified outbreak to a malicious attack on me,
October 11th, 2010, 6:57
Better Shut UP
good luck
So you mean I should be a spectator reading derogatory remarks on me and should not defend myself? If this has been case with you ,will you show same attitude ,if someone raised doubts about you / your company /your skills and post something wrong will you accept it.
Think
October 11th, 2010, 6:59
hddguy wrote:You have a bad attitude, this will never help get what you want.
Better you teach attitude to zebong first
My comments are fair and intellectual. I stated that a 5USD rs323 is exactly the same as 25USD one.
BlackST just pointed out the the difference is in the person who is using it. 5usd or 25usd if you have no idea you are bollocks it anyway.
Any way this is not a college where tutors will direct you into the right direction. Go and find out YOURSELF - post your finding here so that everybody can benefit NOT JUST YOU.
October 11th, 2010, 7:35
Well, it's not completely exact.
I don't use $10 soldering iron, I demonstrated "live" I can use a $10 and NOT make disasters (it's me that make the difference), but in any case a $10 tool has higher probabilities to do disasters in the wrong hands and - albeit lesser - in expert hands.
Anyway , to cut a long story short : all the stuff you find at low price have in common the same "quick and dirt" starting design and probably 99% are copied each other, have no protection toward the drive and have also other problems, but the simple x232 chip works anyway. Seen also many drives with dead comm port due to adapters (the rest was working).
If you really want to make yourself a bullet proof and bullet safe adapter you can do it easily, BUT it's not a 1 chip and 4 caps solution. Some members of this forum have seen what I made a lot of years ago. I didn't think about making series production, it was intended for internal use only, but it really works for me (the "deluxe" version had many useful features).
October 11th, 2010, 7:52
I completely agree with you BlackST.
Anybody with experience can use a $10 Radioshack soldering iron- but that is highly not recommended in DR because you are working on delicate equipment and de soldering an SMD with that $10 usually causes allot of problems.
But again- if you, me or any body here give a "learner" good equipment and try to teach him- the odds are he will bollocks it first, second and third time.
The same applies to everything else.
At the end of the day- the question was generally useless as this forum has MANY threads about rs323- search engines has ten fold more.
So this entire thread is theatricality a waste of space.
I don't mind sharing - but i hate it when people try to grab things.
October 11th, 2010, 8:08
Better Shut UP
good luck
Think
i guess that alot of us are reading many posts here, and whoever had some spare time will answer, and many who knows do not bother and respond but @ the end and i do believe that he did not say anything wrong to have you telling him
Shut UP @ least ignore his post and wait for the proper answer from others, and i do think that who ever reads your post will just ignore your post even when he knows the answer.
I can ask you about something like:
1- can i have this please?
2- give this!!! :evil:
1st. answer means something, the 2nd. means give me or else :evil:
both have the same output but is better than the other as far as i know
anyway, again good luck
:idea:
October 11th, 2010, 9:55
you asked for a good adapter, i point you in the good direction...
if you do not like the direction no problem.
October 11th, 2010, 11:35
ppumkin wrote:My comments are fair and intellectual. I stated that a 5USD rs323 is exactly the same as 25USD one.
I am feeling sad about you , if you could not differntiate between $5 &$25 thing.
Why most of the pros prefer original acelab pc3000 rather than cheaper chinese? I hope you are intelletcual enough to distinguish between quality components , same board can be made using inferior pcb / older chipset and low grade capacitors. Do you prefer low cost chinese stuff? I have not asked to give me training. If you dont know the answer why making cry foul over it. There are so may peoples to answers & I got answer as well. If you dont know answer /do not want to answer ,simple solution to keep quiet.
October 11th, 2010, 11:38
zebong wrote:you asked for a good adapter, i point you in the good direction...
It seems your spectator no is changed better go to a eye specialist
October 11th, 2010, 11:43
ppumkin wrote:I completely agree with you BlackST.
If this thread is waste why you have spent time in posting & wasting other peoples time. If you are not capable to answer help someone ,why to waste other peoples time? why dont you concentratate on your work instead of useless posts? as simple as that
October 11th, 2010, 11:48
Learner, you really have a serious attitude problem. Go sweep some floors in Delhi Commonwealth Games 2010 to make your fellow countrymen proud instead of arguing nonsense. :D
