 Post subject: VMFS file system
PostPosted: October 14th, 2010, 14:57
Are there any tools to extract the vmdks? I cam see it in hex but how do I retrieve it?
It was an ESXI server and the engineer formated the wrong drive array.
 Post subject: Re: VMFS file system
PostPosted: October 14th, 2010, 15:10
Hi
check this link :http://vmetc.com/2008/11/06/vmdk-recovery-tool-available-in-esx-35-update-3/
PostPosted: October 14th, 2010, 15:26
Unfortunately the volume no longer exists. So we need to extract the files using something like get data back or r-studio but neither will recognize the VMFS structure.
PostPosted: October 14th, 2010, 15:33
Ew... You could try a different drive (or raid container) with similar characteristics, create a new vmfs, and try using ddrescue with a starting offset right after the partition table definitions.
There is a linux based vmfs filesystem driver that might also be good to try. It has read-only access, but that would be enough in your case. I can't find the link right now, but I know that it is baked into the Clonezilla live CDs.
Hope that helps... I feel your pain! :shock:
-Cheers, Peter.
PostPosted: October 14th, 2010, 16:21
I may give your first suggestion a try. A friend just called and said he had a similar situation. He went with Ontrack and they returned the vmdks on a NTFS drive. So, there has to be tools out there.
PostPosted: October 14th, 2010, 17:19
Most reputable recovery firms are not limited to using openly-/commercially-available software
Sounds like another case of "IT contractor screwed the pooch and is passing on the recovery costs to the client who doesn't know it was the contractor's fault in the first place"... I see a lot of that these days.
PostPosted: October 15th, 2010, 4:05
VMDK file its just image container (without any compression) , its easy to recovery , you need just cut it in winhex (from boot to boot for example) and rename to *.vmdk :) .
Rarely but it happens that it is "fragmented" , in this situation you need use "virtual translator" in DE for example.
Angel Data Recovery
PostPosted: April 16th, 2011, 0:21
Hi DR-Kiev,
Can you please provide instructions on how to do this? (Cut out the VMDK containers???)
PostPosted: April 18th, 2011, 12:39
illizit wrote:
Hi DR-Kiev,
Easy:
Find start and press Alt+1, find end press Alt+2,
than press Ctrl+Shift+N :)
Angel Data Recovery
PostPosted: April 18th, 2011, 12:54
It is not that easy (usually)
Containers may be fragmented
But the tricky part is that all the changes usually stored separately in update files. And it could be hundreds of them
PostPosted: February 7th, 2012, 12:30
Easy:
HI
Where is the "start"?
and
Where is the "end"?
I hope.. show me details. Please
Thanks you.
# Disk DescriptorFile
version=1
encoding="UTF-8"
CID=f2161662
parentCID=ffffffff
isNativeSnapshot="no"
createType="vmfs"
# Extent description
RW 3904125272 VMFS "vmware_1-flat.vmdk"
# The Disk Data Base
#DDB
ddb.adapterType = "lsilogic"
ddb.geometry.sectors = "63"
ddb.geometry.heads = "255"
ddb.geometry.cylinders = "243020"
ddb.uuid = "60 00 C2 93 93 38 42 5b-19 f5 6e ba a8 cc 90 2c"
ddb.longContentID = "cc2c415bd42ce3a0d46e2b1ff2161662"
ddb.virtualHWVersion = "8"
PostPosted: February 7th, 2012, 12:35
You can find the start of the container by the first sector of the container, or even the start of the file system within the container. The end of container you can figure out based on the partition properties of the start of the file-system.
Users browsing this forum: No registered users and 205 guests
