 Post subject: ST3500620AS
PostPosted: November 14th, 2010, 7:44
i have a ST3500620AS Firmware SD15 7200.11 ( target drive )
it spins up and sounds at power on are normal
not detected in bios
if connected as second drive the system takes much longer to boot
i have another drive same model but different firmware ( donor drive )
when i swapped the pcb the target did not work : click click noise
i swapped back and the drive spins up again and sounds normal
do i go thru the serial port method or will an identical firmware pcb work
i have access to a the same model drive with the same firmware if this would work i would rather backup the donor drive and try its pcb on the target
the target drive is manufactured in 2008 .. would seagate still recover my data ?
 Post subject: Re: ST3500620AS
PostPosted: November 14th, 2010, 8:44
1. You cannot straight swap these PCB's, even the drives s/n is programmed into the PCB.
2. The PCB is not your problem.
Seagate may well recover your drive for you, you need to check the s/n to see if it's covered by that plan. But beware that OEM drives (i.e. tha vast majority of drives out there!) are not covered.
PostPosted: November 21st, 2010, 1:52
Your drive may be a victim of the Seagate 7200.11 BSY bug.
Here are repair procedures for Seagate 7200.11 drives:
http://sites.google.com/site/seagatefix/
http://www.msfn.org/board/index.php?showtopic=128807
Tutorial with photos:
http://www.overclock.net/hard-drives-st ... -pics.html
Pinout of Nokia CA-42 cable's Pop-port connector (use pins 6,7,8):
http://pinouts.ru/CellularPhones-Nokia/ ... nout.shtml
See the following technical bulletin:
http://www.expreview.com/img/topic/seag ... Update.pdf
Seagate were at one time offering free data recovery services to those customers whose drives were affected by the bug. This may still be the case.
After you have repaired your drive, you can apply the following firmware update.
Firmware Update for ST3500320AS, ST3500620AS, ST3500820AS, ST3640330AS, ST3640530AS, ST3750330AS, ST3750630AS, ST31000340AS [207951]:
http://seagate.custkb.com/seagate/crm/s ... cId=207951
If the Windows based updater rejects your drive, then use the CD ISO version. The difference is that one version compares the drive's existing firmware specs against an update matrix file, whereas the other version just checks the drive's model and family.
Users browsing this forum: Google [Bot] and 502 guests
