 Post subject: RAID5 Hint please
PostPosted: October 24th, 2010, 6:49
Any one who can give me a hint on raid 5 configuration, i have a set of 5 disks from a synology nas and can not figure out the configuration ?
Digisupport
Digitalsupport Data Recovery
https://digitalsupport.dk
 Post subject: Re: RAID5 Hint please
PostPosted: October 24th, 2010, 7:55
Check their support pages. Has something gone wrong with it ?
If you are doing data recovery on it, I think you will not find your answers in this forum.
https://www.mjm.co.uk/
PostPosted: October 24th, 2010, 8:06
The nas was taken out by over voltage, but disks are fine, but the owner tryed to recover, and firmware partition seems to be deleted, so i need to setup the array in r-studio but cant find the rigth disk order.
What will it cost to get remote sup on this case..
PostPosted: October 25th, 2010, 2:23
R-studio will not help. This NAS uses xFS system.
PostPosted: October 25th, 2010, 23:03
try use UFS explorer professional.
it support build virtual raid array and XFS system.
PostPosted: October 26th, 2010, 9:49
As far as I know, Synology doesn't use XFS file system. Normally it uses a type of
customized ReiserFS.
Either UFS Explorer pro or R-studio will help when you are going to do RAW recovery.
They won't reconstruct file system. Parameters: 64KB, Backward dyn. should work.
Users browsing this forum: Google [Bot] and 70 guests
