 Post subject: Toshiba mk4032gax PCB Question
PostPosted: November 1st, 2010, 13:04
Guys,
i got this Toshiba mk4032gax
here is the PCB Attached,
could anyone tell me what is this chip please?
this is the Working PCB i have, and am going to replace this chip with a defected one
many thnx
 Post subject: Re: Toshiba mk4032gax PCB Question
PostPosted: November 1st, 2010, 13:06
Spindle / VCM combo chip. Or do you need the part number ?
PostPosted: November 1st, 2010, 13:12
wow, that was quick man
well, i got my client hdd with this part burned, and i found one here which i was planning to replace with this
the image here is from the working pcb hdd same model
do u think replacing this burned chip will get it back to work?
thnx again
PostPosted: November 1st, 2010, 18:57
maybe get IC12 from bad board and put on you good board then use your good board will be easier.
PostPosted: November 3rd, 2010, 3:55
You can sometimes infer the function of a chip by searching the datasheets for similar part number prefixes:
http://www.datasheetarchive.com/search. ... 4&sub.y=12
Users browsing this forum: Google [Bot] and 224 guests
