 Post subject: Problem with Seagate 7200.11 st31500341as
PostPosted: November 9th, 2010, 8:07
Hello! I have a problem with a disk Seagate 7200.11 st31500341AS
It spins normaly everything ok but I am getting SMART error on bios while booting. It is detectable.
I login to windows (win 7x64) and then I can see it on my computer but mouse pointer freezes all the time and i can't have any access to the data I see them but when i double click for further folder browsing it freeze and I need to reset my computer. I put it on an external usb and esata case but again i have the same problem. Will the fix with nokia cable work on my? What else should i try at least backup my data and then sending it back for RMA.
Thanks.
 Post subject: Re: Problem with Seagate 7200.11 st31500341as
PostPosted: November 9th, 2010, 13:31
Image to a good drive using non-windows imaging s/w.
e.g. dd_rescue or Media Tools Pro
Better still if you really need your data, send to a pro.
PostPosted: November 11th, 2010, 11:15
Hurry up save all your important DATA, the HD can crash at any moment.
The some thing hapend to me, After that it was no more detected by the BIOS.
PostPosted: November 11th, 2010, 11:17
You can also use the Seagate HD utilitie that scan it in dos mode.
PostPosted: November 12th, 2010, 18:33
I conected with sata to usb addapter and with 10kb/s rate i copy all the data and then I send it for RMA.... :evil:
PostPosted: November 12th, 2010, 21:23
Better to do this and get off your data and RMA the drive. Never trust a failing drive clone it ASAP work with clone and go from there.
Iorana Haraharaini
Users browsing this forum: No registered users and 422 guests
