 Post subject: Question about PCB HD
PostPosted: December 19th, 2010, 13:21
I would like to know what is saved on chip on PCB of the HD.
The file system ?
The list of files put on Hard disk ?
or what ?
Thank you.
 Post subject: Re: Question about PCB HD
PostPosted: December 19th, 2010, 14:16
Hi.
well in a regular HDD, no storage is made on a pcb chip...
you have basicaly two controllers, electric engine controller and a controller/processor that regulates the comunications and the read/write head arm, this one has some data code like a bios to boot the drive and go to the service track and load the firmware
you have also a memory chip that it is used for buffering and initializing the firmware
the firmware is loaded from a service track in the drive wich you don't have access normally... only with special and expensive tools
Users browsing this forum: No registered users and 67 guests
