 Post subject: Can't read ST3300620AS Firmware 3.AAC
PostPosted: November 12th, 2010, 22:28
It was mounted in Antec MX-1 external enclosure with fan. It was used strictly as storage. Turned on, copied to or from & turned off. I removed it from MX-1 & used a Coolmax CD-350 adaptor to read it. Same results.
It spins up & makes very slight tick...tick, tick sound. I get USB icon but no "safe to disconnect" box. It is not seen in "disk management".
I have the same drive with firmware version 3.AAD that works perfectly.
Is it the PCB?
Will the PCB from the good drive fix the bad drive?
Do I need a pro?
Thanks for all the help,
Dave
 Post subject: Re: Can't read ST3300620AS Firmware 3.AAC
PostPosted: November 13th, 2010, 1:08
Tick Tick Tick sound is normally heads or could be stuck heads. Not a lot to go on. But no the PCB will not help you out in changing it in this case. What is your drive make and model?
Iorana Haraharaini
PostPosted: November 13th, 2010, 4:30
The drive is a Seagate ST3300620AS firmware version 3.AAC. 300 Gb drive.
PostPosted: November 13th, 2010, 21:20
The OP stated that the drive spins up, so it's not a stiction problem.
See subject header.
PostPosted: November 13th, 2010, 21:58
Dave[/quote]
See subject header.
Hummm do not understand this one QUOTE IT SPINS UP AND MAKES A VERY SLIGHT TICK .......TICK SOUND..................
I never stated Striction problem I stated head problem..... tick tick tick tick tick tick tick tick tick ...................... Read a littler closer please ................
Iorana Haraharaini
PostPosted: November 13th, 2010, 22:11
"Stuck heads" sounds like stiction to me.
Maybe something got lost in the translation. :roll:
PostPosted: November 13th, 2010, 22:19
No not all head that stick to a platter mean Striction on this one. Heads can stick to a platter and it is not Striction that causes this problem. Sorry but just becasue heads are stuck to a platter do not assume that striction is involved in this one.
Iorana Haraharaini
PostPosted: November 13th, 2010, 22:38
I was referring to "stiction", not "striction". That's something else altogether.
http://www.thefreedictionary.com/striction
I have no idea how it relates to hard drives, though. :roll:
PostPosted: November 13th, 2010, 23:17
I really think you need a life. :mrgreen: You seem to have way too many issues with the people of this forum. You belong to all the forums on the net go and visit them and leave this one alone if you are so unhappy here. :lol:
Iorana Haraharaini
PostPosted: November 14th, 2010, 5:24
I would have said Frank is president of the pedantic society, but he'd probably come back and say "I think you'll find it's the pedantry society"
P.S. It's a joke, not a dig Frank :D
PostPosted: November 14th, 2010, 18:08
Now that I, at least, have learned a couple new words that I will most likely never use, could I get an answer. Please? All I know about hard drives comes on a small sheet of paper inside the box they come in when they are brand new. I read some of these posts & an article on how to take one apart & thought you guys could save me about a hundred years of research. I know how difficult it is to diagnose problems long distance so if it can't be done in this case, I will move on. Thanks for the entertainment. :)
PostPosted: November 14th, 2010, 22:37
Sorry for all this one sailorman22, If your drive makes a tick tick tick noise you really can not fix this one on your own. You might want to check on the Seagate forum and see if you drive is under warrenty and send it in for RMA. Otherwise you will need to take this to someone in your area and have the heads looked at on this drive. More than likely one has failed and that is why it is tick tick tick on you. The heads are not able to read the Service Area zone and start the drive to initialize. That is your problem on this one.
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 154 guests
