 Post subject: I Cant fix Partition Table/MBR - Seagate ST31500341AS @ NTFS
PostPosted: November 18th, 2010, 21:09
Hello boys, i've a BIG problem with my seagate HD
I use the HD to storage my music, NO systems inside of the HD
When I connect on the motherboard, the BIOS can see the HD, but the Windows cant see.
Works when i connect using USB only like we can see:
i've tried use TestDisk, but i cant find my lost partitions, when i try to use Partiton Magic 8:
Look the R-Studio screen:
EASEUS Partition Master
No way to fix the HD without lost my files? No way only to recover my files?
Sry for my english "/
 Post subject: Re: I Cant fix Partition Table/MBR - Seagate ST31500341AS @ NTFS
PostPosted: November 19th, 2010, 2:26
You have option to clone HDD to a new one and then run a raw recovery program on this one. Then you can have back all your music in raw data and rename it and organize it again. That is one option you have on this one. Other option is that a pro knows how to fix this and can help you out on it. Work on this drive without clone you risk chance of losing all data on it. Easier to make mistakes on the cloned drive and try things on it than on your data drive.
Iorana Haraharaini
PostPosted: November 19th, 2010, 16:50
Thanks poehere
You know any god application for OSX or Windows 7 where i can clone the original Hard Drive?
PostPosted: November 19th, 2010, 21:10
*sry, wrong thread*
PostPosted: November 20th, 2010, 3:17
There are several good cloning software tools out there. Most people here seem to like ddresue to do their cloning with. You can try this one. There is also Rdrive copy and some others around too.
Iorana Haraharaini
PostPosted: November 20th, 2010, 12:49
You can also use DMDE to clone.
ACELab partner
PostPosted: November 21st, 2010, 4:35
HDClone:
http://www.miray.de/products/sat.hdclone.html
Users browsing this forum: Google [Bot] and 358 guests
