 Post subject: i dont recovery seagate 7.200 12 no solution
PostPosted: November 21st, 2010, 9:55
I made the exchange of the reading head, and in pc3k it continues beating and I do not obtain access to the data in terminal hyper is giving to this log of Failed error you load to over Lay 00000004 LED00000CC FAddr: 00289581, hd seagate barracuda 7,200-12 1 TB I do not obtain access the data therefore same head changing continues with same error, somebody knows to help in this case me
SOS DATA RECOVERY - BRAZIL BY EMERSON COSTA
 Post subject: Re: i dont recovery seagate 7.200 12 no solution
PostPosted: November 21st, 2010, 9:59
I changed to the head of reading of hd seagate 7200-12 and I do not obtain access to the data, somebody has the solution for this case
PostPosted: November 22nd, 2010, 23:50
are you sure can disable heads in pc3000UDMA?
are you sure pcb is original?what's that problem?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: November 25th, 2010, 16:46
Is there any scratch on platter ?
What was the original problem ?
Why did you change heads ?
PostPosted: November 25th, 2010, 17:27
Rameez is right, you should indicate properly the original problem and your steps for the recovery attempt, or else it will be hard to draw a picture of what happened.
PostPosted: November 26th, 2010, 20:13
i think this is not bad head !!!
to carry and to save firmware seagate
Users browsing this forum: No registered users and 422 guests
