 Post subject: Ares c64K
PostPosted: November 28th, 2010, 16:56
is there anyone who did have success ever with Maxtor 2F040l0 series HDD for selfscan?
 Post subject: Re: Ares c64K
PostPosted: November 28th, 2010, 18:57
Always, if drive not
worn out. Partial, depending on surface and head.
PostPosted: November 28th, 2010, 19:46
Ares Maxtor drives are famous for shitty platters quality
Usually there is nothing to scan - it's already cold dead
PostPosted: November 28th, 2010, 20:41
Thanks to all of you for response. actually i have a quantity of this model. selfscan doesn't work at salvation data console. modules are ok. whole drive shows bad sectors. i tried other softwares to remove bad sectors but they don't work. hard drive shows bad sectors as earlier. anyone has solution then plz guide me.
PostPosted: November 28th, 2010, 21:47
Hmm
One more time
1. These drive are garbage
2. These drives usually end up with bad surface
3. That usually means drives (this particular model) are not fixable and selfscan won't help you
PostPosted: November 29th, 2010, 2:33
Forget Salvationdata tools. If you really want to squeeze out some more life from them you need to check surface and head condition - prescreen - then 'tweak' what needed, depending on what happens. Can't help directly, sorry.
Users browsing this forum: Google [Bot] and 142 guests
