 Post subject: Seagate 7200.12 160 GB BSY problem
PostPosted: November 29th, 2010, 23:58
ASCII Diag mode
F3 T>m0,2,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewr
ite Retries = 0000
Init SMART Fail
LED:000000CC FAddr:0024E599
what happen?
 Post subject: Re: Seagate 7200.12 160 GB BSY problem
PostPosted: November 30th, 2010, 4:24
Well, it's obvious that something went wrong.
Can you post what was the original problem and the steps taken?
PostPosted: November 30th, 2010, 12:37
Was this the busy problem or the 0 LBA problem. You have just done the 0 LBA fix. I suggest that maybe if this one was the busy problem you should do a little research here and find the way to do the Busy fix. In busy fix the PCB has to be removed (hint) in 0 LBA you use this code. Maybe this can tell you what went wrong.
1st did BIOS recognize your HDD but give you a 0 - LBA? if so you chose correctly if not then you chose wrong.
2nd did the BIOS not see your drive??? if yes then you chose wrong.
3rd what made you think this was the busy problem on your drive? What was wrong with it in the first place?
Iorana Haraharaini
PostPosted: November 30th, 2010, 15:01
What EXACT model are we talking about ?
PostPosted: November 30th, 2010, 20:19
SEAGATE 7200.12 160 GB sata
MODEL: ST3160318AS
FW: CC45
DATE CODE: 10173
SC: WU
PostPosted: November 30th, 2010, 20:39
HDD has BSY problem NOT 0 LBA problem
PostPosted: November 30th, 2010, 20:49
seagate-drives-led-000000cc-bug-aka-busy-bug-faq-t17831.html
PostPosted: November 30th, 2010, 20:50
:) Its obvious that many people don't understand how F3 architecture works.
Zero Alpha: zeroalpha.com.au
PostPosted: November 30th, 2010, 20:59
what is the solution? PM
PostPosted: November 30th, 2010, 21:07
send it to pro?
PostPosted: November 30th, 2010, 21:08
you are a pro? ha ha ha
PostPosted: November 30th, 2010, 21:23
Button called search and then read - If this is not in your native language try google to translate it. Then read there is 2 solution on this one
1 = 0 LBA
2nd = Busy
You have to chose the right one.
Iorana Haraharaini
PostPosted: December 1st, 2010, 3:11
Here are repair procedures for Seagate 7200.11 drives:
http://sites.google.com/site/seagatefix/
http://www.msfn.org/board/index.php?showtopic=128807
Tutorial with photos:
http://www.overclock.net/hard-drives-st ... -pics.html
Pinout of Nokia CA-42 cable's Pop-port connector (use pins 6,7,8):
http://pinouts.ru/CellularPhones-Nokia/ ... nout.shtml
PostPosted: December 1st, 2010, 7:30
Its a 7200.12 so it is not the 7200.11 BSY problem.
7200.12's have a different problem which needs pro help.
PostPosted: December 2nd, 2010, 2:00
I have 500gb 7200.12 drive which gives output Rst 0x10M and nothing happens further. I am sure this is not typical 7200.11 defect. What is correct command for Data recovery?
PostPosted: December 2nd, 2010, 2:49
The 7200.11 LBA 0 bug fix procedure can be applied to 7200.12 drives, at least in some cases.
See this thread:
seagate-barracuda-7200-lba-t17640.html
BSY issues may be another matter. There are no doubt many possible reasons for a drive to hang in the BSY state.
PostPosted: December 2nd, 2010, 3:38
Luckily the OP has all the pro gear the lamers and wannabes can only DREAM OF.
PM sent.
PostPosted: December 2nd, 2010, 5:24
Why don't you tell us? :(
PostPosted: October 20th, 2013, 22:40
hi guys
i have same as problem too.
hdd seagate baracuda 7200.12
v. ST3250318AS
firmware CC45
F3 2>Z
Spin Down Complete
Elapsed Time 0.430 msecs
F3 2>U
Spin Up Complete
Elapsed Time 5.053 secs
F3 1>N1
Init SMART Fail
anyone can help ? thank u
Users browsing this forum: Google [Bot] and 40 guests
