 Post subject: I need help with Seagate ST96812A
PostPosted: December 2nd, 2010, 6:15
Hi all,
I need help with a seagate ST96812A (MERC2 - Momentus 5400.2 - 60 Gb - 2.5")
SN: 3PJ
FW: 3.06
Site AMK
With start-up the heads click 3 times and after a while the disc spins down. The drive does not come ready.
The terminal gives the following output:
Interface task reset
4096k x 16 buffer detected
MERC2 - 1_Disk 0.05 01
Buzz - -20-06 15:53
Head Mask 00,01 - Head Mask 00,05 - Head Mask 00,06 - Head Mask 00,07 - Head Mask 00,08 - Head Mask 00,09 - Head Mask 00,0A - Head Mask 00,0B - Head Mask 00,0C - Head Mask 00,0D -
F>
F>
Age=00 Type=00 MxCyl=0000052E MxHd=31A MxSct=2000 BSz=003B TCode=00000000
F>
I have changed the heads (from a working donor) but the terminal gives exactly the same results.
Any proposals? Thanks.
Edsel
 Post subject: Re: I need help with Seagate ST96812A
PostPosted: December 2nd, 2010, 17:23
Did you try changing pcb ?
PostPosted: December 2nd, 2010, 19:02
Yes, I changed the pcb but then it was clicking too.
Edsel
PostPosted: December 2nd, 2010, 22:38
What tools do you have. This will help to give you an idea of what to do next. Do you use Atola, ACE. or SD? If no tools you are just reading from terminal connector.
Iorana Haraharaini
PostPosted: December 3rd, 2010, 3:15
To me, the fact it is showing Age 00 and mxhd 31 makes me think about serious sa corruption or the drive was badly wanked by someone before sending to the op... No wonder it is clicking.
PostPosted: December 3rd, 2010, 4:01
I have PC3000 isa.
Edsel
PostPosted: December 3rd, 2010, 8:06
Doesn't help...
Users browsing this forum: No registered users and 103 guests
