 Post subject: WD800BB
PostPosted: December 7th, 2010, 12:42
Hi to all!
PCB BAD, swap rom.
No access data. :shock:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 64
Zone allocation table................... : Ok
SA SPT.................................. : 533
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 08.94C
ROM generation.......................... : 08.94C
Link table version...................... : 01.B2.
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
ROM Firmware version.................... : 0894C
Service area:
SA dir reading.......................... : Ok (Copy 0)
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
SA Firmware version..................... : 0894C
View ROM information
ROM Modules
0A : Head map
30 : SA Translator
47 : SA Adaptives
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : 430/1072
1 : 1 : 4C2/1218
Read ROM modules
Into file............................... : \Data\ROM
Module : 0A............................. : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
SA surface verification
Cyl: -1 Head: 0......................... : Ok
Cyl: -1 Head: 1......................... : Ok
Cyl: -2 Head: 0......................... : Ok
Cyl: -2 Head: 1......................... : Ok
Cyl: -3 Head: 0......................... : BAD:
Cyl: -3 Head: 1......................... : BAD:
Cyl: -4 Head: 0......................... : Ok
Cyl: -4 Head: 1......................... : Ok
Cyl: -5 Head: 0......................... : Ok
Cyl: -5 Head: 1......................... : Ok
Cyl: -6 Head: 0......................... : Ok
Cyl: -6 Head: 1......................... : Ok
Cyl: -7 Head: 0......................... : Ok
Cyl: -7 Head: 1......................... : Ok
Cyl: -8 Head: 0......................... : BAD:
Cyl: -8 Head: 1......................... : BAD:
Cyl: -9 Head: 0......................... : Ok
Cyl: -9 Head: 1......................... : Ok
Cyl: -10 Head: 0........................ : BAD: 1
Cyl: -10 Head: 1........................ : BAD: 1
Cyl: -11 Head: 0........................ : BAD:
Cyl: -11 Head: 1........................ : BAD:
Cyl: -12 Head: 0........................ : Ok
Cyl: -12 Head: 1........................ : Ok
Cyl: -13 Head: 0........................ : Ok
Cyl: -13 Head: 1........................ : Ok
Cyl: -14 Head: 0........................ : Ok
Cyl: -14 Head: 1........................ : Ok
Cyl: -15 Head: 0........................ : Ok
Cyl: -15 Head: 1........................ : Ok
Cyl: -16 Head: 0........................ : Ok
Cyl: -16 Head: 1........................ : Ok
Cyl: -17 Head: 0........................ : Ok
Cyl: -17 Head: 1........................ : Ok
Cyl: -18 Head: 0........................ : Ok
Cyl: -18 Head: 1........................ : Ok
Cyl: -19 Head: 0........................ : Ok
Cyl: -19 Head: 1........................ : Ok
Cyl: -20 Head: 0........................ : Ok
Cyl: -20 Head: 1........................ : Ok
Cyl: -21 Head: 0........................ : Ok
Cyl: -21 Head: 1........................ : Ok
Cyl: -22 Head: 0........................ : Ok
Cyl: -22 Head: 1........................ : Ok
Cyl: -23 Head: 0........................ : Ok
Cyl: -23 Head: 1........................ : Ok
Cyl: -24 Head: 0........................ : Ok
Cyl: -24 Head: 1........................ : Ok
Cyl: -25 Head: 0........................ : Ok
Cyl: -25 Head: 1........................ : Ok
Cyl: -26 Head: 0........................ : Ok
Cyl: -26 Head: 1........................ : Ok
Cyl: -27 Head: 0........................ : Ok
Cyl: -27 Head: 1........................ : Ok
Cyl: -28 Head: 0........................ : Ok
Cyl: -28 Head: 1........................ : Ok
Cyl: -29 Head: 0........................ : Ok
Cyl: -29 Head: 1........................ : Ok
Cyl: -30 Head: 0........................ : Ok
Cyl: -30 Head: 1........................ : Ok
Cyl: -31 Head: 0........................ : Ok
Cyl: -31 Head: 1........................ : Ok
Cyl: -32 Head: 0........................ : Ok
Cyl: -32 Head: 1........................ : Ok
Cyl: -33 Head: 0........................ : Ok
Cyl: -33 Head: 1........................ : Ok
Cyl: -34 Head: 0........................ : Ok
Cyl: -34 Head: 1........................ : Ok
Cyl: -35 Head: 0........................ : Ok
Cyl: -35 Head: 1........................ : Ok
Cyl: -36 Head: 0........................ : Ok
Cyl: -36 Head: 1........................ : Ok
Cyl: -37 Head: 0........................ : Ok
Cyl: -37 Head: 1........................ : Ok
Cyl: -38 Head: 0........................ : Ok
Cyl: -38 Head: 1........................ : Ok
Cyl: -39 Head: 0........................ : Ok
Cyl: -39 Head: 1........................ : Ok
Cyl: -40 Head: 0........................ : Ok
Cyl: -40 Head: 1........................ : Ok
Cyl: -41 Head: 0........................ : Ok
Cyl: -41 Head: 1........................ : Ok
Cyl: -42 Head: 0........................ : BAD:
Cyl: -42 Head: 1........................ : Ok
Cyl: -43 Head: 0........................ : Ok
Cyl: -43 Head: 1........................ : Ok
Cyl: -44 Head: 0........................ : Ok
Cyl: -44 Head: 1........................ : Ok
Cyl: -45 Head: 0........................ : Ok
Cyl: -45 Head: 1........................ : Ok
Cyl: -46 Head: 0........................ : Ok
Cyl: -46 Head: 1........................ : Ok
Cyl: -47 Head: 0........................ : Ok
Cyl: -47 Head: 1........................ : Ok
Cyl: -48 Head: 0........................ : Ok
Cyl: -48 Head: 1........................ : Ok
Cyl: -49 Head: 0........................ : Ok
Cyl: -49 Head: 1........................ : Ok
Cyl: -50 Head: 0........................ : BAD: 1 - 8
Cyl: -50 Head: 1........................ : BAD: 1 - 42
Cyl: -51 Head: 0........................ : Ok
Cyl: -51 Head: 1........................ : Ok
Cyl: -52 Head: 0........................ : Ok
Cyl: -52 Head: 1........................ : Ok
Cyl: -53 Head: 0........................ : Ok
Cyl: -53 Head: 1........................ : Ok
Cyl: -54 Head: 0........................ : Ok
Cyl: -54 Head: 1........................ : Ok
Cyl: -55 Head: 0........................ : Ok
Cyl: -55 Head: 1........................ : Ok
Cyl: -56 Head: 0........................ : Ok
Cyl: -56 Head: 1........................ : Ok
Cyl: -57 Head: 0........................ : Ok
Cyl: -57 Head: 1........................ : Ok
Cyl: -58 Head: 0........................ : Ok
Cyl: -58 Head: 1........................ : Ok
Cyl: -59 Head: 0........................ : Ok
Cyl: -59 Head: 1........................ : Ok
Cyl: -60 Head: 0........................ : Ok
Cyl: -60 Head: 1........................ : Ok
Cyl: -61 Head: 0........................ : Ok
Cyl: -61 Head: 1........................ : Ok
Cyl: -62 Head: 0........................ : Ok
Cyl: -62 Head: 1........................ : Ok
Cyl: -63 Head: 0........................ : Ok
Cyl: -63 Head: 1........................ : Ok
Heads test
Cylinder to test........................ : -50
Heads to test........................... : 0,1
Head 0.................................. : Error W : 533
Head 1.................................. : Error W : 533
exchange of heads? :?:
Нет ничего невозможного
 Post subject: Re: WD800BB
PostPosted: December 7th, 2010, 13:10
Looks like the cylinder heads are trying to write to for test has bads
What is the result of SA structure test?
PostPosted: December 7th, 2010, 13:40
SA structure test
Module 01 Copy 0........................ : Ok
Module 01 Copy 1........................ : Ok
Module 17 Copy 0........................ : Ok
Module 17 Copy 1........................ : Ok
Module 1B Copy 0........................ : Ok
Module 1B Copy 1........................ : Ok
Module 4C Copy 0........................ : Ok
Module 4C Copy 1........................ : Ok
Module 13 Copy 0........................ : Ok
Module 13 Copy 1........................ : Ok
Module 11 Copy 0........................ : Ok
Module 11 Copy 1........................ : Ok
Module 35 Copy 0........................ : Ok
Module 35 Copy 1........................ : Ok
Module 02 Copy 0........................ : Ok
Module 02 Copy 1........................ : Ok
Module 33 Copy 0........................ : Ok
Module 33 Copy 1........................ : Ok
Module 34 Copy 0........................ : Ok
Module 34 Copy 1........................ : Ok
Module 15 Copy 0........................ : Ok
Module 15 Copy 1........................ : Ok
Module 1E Copy 0........................ : Ok
Module 1E Copy 1........................ : Ok
Module 12 Copy 0........................ : Ok
Module 12 Copy 1........................ : Ok
Module 1C Copy 0........................ : Ok
Module 1C Copy 1........................ : Ok
Module reading error: Physical read error C/H/S: -3/0/148 - Device Error Detected: "DISK DAM ERROR"
Module 31 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -3/1/148 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 31 Copy 1........................ : Error
Module reading error: Physical read error C/H/S: -8/0/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 32 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -8/1/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 32 Copy 1........................ : Error
Module 50 Copy 0........................ : Ok
Module 50 Copy 1........................ : Ok
Module 51 Copy 0........................ : Ok
Module 51 Copy 1........................ : Ok
Module 52 Copy 0........................ : Ok
Module 52 Copy 1........................ : Ok
Module 53 Copy 0........................ : Ok
Module 53 Copy 1........................ : Ok
Module 36 Copy 0........................ : Ok
Module 36 Copy 1........................ : Ok
Module 2F Copy 0........................ : Ok
Module 2F Copy 1........................ : Ok
Module 28 Copy 0........................ : Ok
Module 28 Copy 1........................ : Ok
Module 0C Copy 0........................ : Ok
Module 0C Copy 1........................ : Ok
Module 2A Copy 0........................ : Ok
Module 2A Copy 1........................ : Ok
Module 29 Copy 0........................ : Ok
Module 29 Copy 1........................ : Ok
Module 60 Copy 0........................ : Ok
Module 60 Copy 1........................ : Ok
Module 40 Copy 0........................ : Ok
Module 40 Copy 1........................ : Ok
Module 41 Copy 0........................ : Ok
Module 41 Copy 1........................ : Ok
Module 42 Copy 0........................ : Ok
Module 42 Copy 1........................ : Ok
Module 43 Copy 0........................ : Ok
Module 43 Copy 1........................ : Ok
Module 49 Copy 0........................ : Ok
Module 49 Copy 1........................ : Ok
Module 4A Copy 0........................ : Ok
Module 4A Copy 1........................ : Ok
Module 04 Copy 0........................ : Ok
Module 04 Copy 1........................ : Ok
Module 05 Copy 0........................ : Ok
Module 05 Copy 1........................ : Ok
Module 06 Copy 0........................ : Ok
Module 06 Copy 1........................ : Ok
Module 07 Copy 0........................ : Ok
Module 07 Copy 1........................ : Ok
Module 37 Copy 0........................ : Ok
Module 37 Copy 1........................ : Ok
Module reading error: Physical read error C/H/S: -10/0/1 - Device Error Detected: "DISK DAM ERROR"
Module 21 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -10/1/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 21 Copy 1........................ : Error
Module reading error: Physical read error C/H/S: -10/0/63 - Device Error Detected: "DISK DAM ERROR"
Module 22 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -10/1/63 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 22 Copy 1........................ : Error
Module 23 Copy 0........................ : Ok
Module 23 Copy 1........................ : Ok
Module 24 Copy 0........................ : Ok
Module 24 Copy 1........................ : Ok
Module 25 Copy 0........................ : Ok
Module 25 Copy 1........................ : Ok
Module 26 Copy 0........................ : Ok
Module 26 Copy 1........................ : Ok
Module reading error: Physical read error C/H/S: -11/0/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 2D Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -11/1/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 2D Copy 1........................ : Error
Module 2E Copy 0........................ : Ok
Module 2E Copy 1........................ : Ok
Module C4 Copy 0........................ : Ok
Module C4 Copy 1........................ : Ok
Module C5 Copy 0........................ : Ok
Module C5 Copy 1........................ : Ok
Module CC Copy 0........................ : Ok
Module CC Copy 1........................ : Ok
Module CA Copy 0........................ : Ok
Module CA Copy 1........................ : Ok
Module CB Copy 0........................ : Ok
Module CB Copy 1........................ : Ok
Module CD Copy 0........................ : Ok
Module CD Copy 1........................ : Ok
Module CF Copy 0........................ : Ok
Module CF Copy 1........................ : Ok
Module CE Copy 0........................ : Ok
Module CE Copy 1........................ : Ok
Module 91 Copy 0........................ : Ok
Module 91 Copy 1........................ : Ok
Module 90 Copy 0........................ : Ok
Module 90 Copy 1........................ : Ok
Module 92 Copy 0........................ : Ok
Module 92 Copy 1........................ : Ok
Module C1 Copy 0........................ : Ok
Module C1 Copy 1........................ : Ok
Module C2 Copy 0........................ : Ok
Module C2 Copy 1........................ : Ok
Module C7 Copy 0........................ : Ok
Module C7 Copy 1........................ : Ok
Module B1 Copy 0........................ : Ok
Module B1 Copy 1........................ : Ok
Module E0 Copy 0........................ : Ok
Module E0 Copy 1........................ : Ok
Module E8 Copy 0........................ : Ok
Module E8 Copy 1........................ : Ok
Module FE Copy 0........................ : Ok
Module FE Copy 1........................ : Ok
Module D5 Copy 0........................ : Ok
Module D5 Copy 1........................ : Ok
Module DA Copy 0........................ : Ok
Module DA Copy 1........................ : Ok
Module DB Copy 0........................ : Ok
Module DB Copy 1........................ : Ok
Module DF Copy 0........................ : Ok
Module DF Copy 1........................ : Ok
Module DD Copy 0........................ : Ok
Module DD Copy 1........................ : Ok
Module D6 Copy 0........................ : Ok
Module D6 Copy 1........................ : Ok
Module D7 Copy 0........................ : Ok
Module D7 Copy 1........................ : Ok
Module D2 Copy 0........................ : Ok
Module D2 Copy 1........................ : Ok
Module BB Copy 0........................ : Ok
Module BB Copy 1........................ : Ok
Module D9 Copy 0........................ : Ok
Module D9 Copy 1........................ : Ok
Module D4 Copy 0........................ : Ok
Module D4 Copy 1........................ : Ok
Module DC Copy 0........................ : Ok
Module DC Copy 1........................ : Ok
Module D0 Copy 0........................ : Ok
Module D0 Copy 1........................ : Ok
Module D3 Copy 0........................ : Ok
Module D3 Copy 1........................ : Ok
Module BA Copy 0........................ : Ok
Module BA Copy 1........................ : Ok
Module B9 Copy 0........................ : Ok
Module B9 Copy 1........................ : Ok
Module BC Copy 0........................ : Ok
Module BC Copy 1........................ : Ok
Module FD Copy 0........................ : Ok
Module FD Copy 1........................ : Ok
Module FB Copy 0........................ : Ok
Module FB Copy 1........................ : Ok
Module E6 Copy 0........................ : Ok
Module E6 Copy 1........................ : Ok
Module E7 Copy 0........................ : Ok
Module E7 Copy 1........................ : Ok
Module BE Copy 0........................ : Ok
Module BE Copy 1........................ : Ok
Module B8 Copy 0........................ : Ok
Module B8 Copy 1........................ : Ok
Module BF Copy 0........................ : Ok
Module BF Copy 1........................ : Ok
Module FC Copy 0........................ : Ok
Module FC Copy 1........................ : Ok
Module EE Copy 0........................ : Ok
Module EE Copy 1........................ : Ok
Module E1 Copy 0........................ : Ok
Module E1 Copy 1........................ : Ok
Module E2 Copy 0........................ : Ok
Module E2 Copy 1........................ : Ok
Module E3 Copy 0........................ : Ok
Module E3 Copy 1........................ : Ok
Module E4 Copy 0........................ : Ok
Module E4 Copy 1........................ : Ok
Module E5 Copy 0........................ : Ok
Module E5 Copy 1........................ : Ok
Module E9 Copy 0........................ : Ok
Module E9 Copy 1........................ : Ok
Module DE Copy 0........................ : Ok
Module DE Copy 1........................ : Ok
Module FA Copy 0........................ : Ok
Module FA Copy 1........................ : Ok
Access violation at address 03EC824A in module 'PCWDCM~1.DLL'. Read of address B26A0772
SA structure test
Module reading error: Physical read error C/H/S: -8/0/1 - Device Error Detected: "DISK DAM ERROR"
Module reading error: Physical read error C/H/S: -11/0/1 - Device Error Detected: "DISK DAM ERROR"
Access violation at address 03EC824A in module 'PCWDCM~1.DLL'. Read of address B2C058EA
PostPosted: December 8th, 2010, 16:15
I believe it is fairly common knowledge that if you have ANY bad modules, even modules that *shouldn't* effect the functionality of the drive; more often then not the drive will not function properly until these modules are repaired or replaced with compatible working modules.
Of course in this situation it is important to discover if the heads are in reliable condition to perform FW writes, as you could do more harm then good if they are not.
PostPosted: December 9th, 2010, 8:38
Ok, my friend!
BAD CYLS
-3 MODULE 31 (TRANSLATOR)
-8 MODULE 32 RELO BAD BLOCK
-10 MODULES 21 , 22 SMART
-11 MODULE 2D DEBUG LOG
-42
-50
HOW HAVE OTHER MODULES ALLOCATE CYLINDRES?
:idea:
PostPosted: December 9th, 2010, 10:40
Rebuilding translator should help with critical modules 31 & 32.
http://www.datasaversllc.com
PostPosted: December 9th, 2010, 13:07
Translator regeneration error!
METHOD...................: USE P-List ONLY
error code: 3C05........: FMT ERR PDLIST WRT FAIL
PostPosted: December 9th, 2010, 13:21
There may be some problem with heads writing (especially since it corrupted track -50 doing the heads test)
Sent PM
PostPosted: December 21st, 2010, 6:21
Sent PM
THANKS YOUR HELP! :!:
SOLVED!!
PostPosted: December 21st, 2010, 11:23
+1 to DRC =)
PostPosted: April 22nd, 2011, 15:11
drc:
Is it possible to know the corrective action as I think I have similar problem and you have left me in suspense :? :?: .
Thanks in advance!
Douglas
Users browsing this forum: Google [Bot] and 230 guests
