 Post subject: Need help with last step in retrieving data.
PostPosted: December 7th, 2010, 13:03
I need help diagnosing new symptoms on a failed drive (Seagate ST3320620A from Maxtor external, 320gb). The drive suffered a bearing failure, most likely due to heat, and I need to retrieve data.
I've successfully free'd the seized spindle using a makeshift clean room (bathroom) and home-made tools. The hard drive spins up quickly to full speed, pauses for a few seconds, and then the trouble begins:
First it makes a boink sound (like a marble dropping), then proceeds to make slow clicks (8-10 clicks), about 1 per second. It then pauses for a few seconds and repeats the same sequence of sounds. My research tells me it is seeking track 0.
Other Notes: Drive is IDE, I can not connect to it on IDE interface, or using USB to IDE connector. I can not see it in Disk Management. Also does not show up in Seatools. Platters are clean, data should still be intact.
So where I need help is what to do next, I'm hoping for suggestion on diagnosing the PCB and the heads?
Thanks.
 Post subject: Re: Need help with last step in retrieving data.
PostPosted: December 7th, 2010, 13:08
If you haven't already completely destroyed it (and if it wasn't already destroyed when you started working on it), your only hope will be a data recovery professional. Keep in mind they will likely charge you 2x-10x what a normal quote would have been since you have already been messing with it.
PostPosted: December 7th, 2010, 13:54
Out of curiosity, what is a "makeshift clean room (bathroom)" ? :shock:
PostPosted: December 7th, 2010, 19:07
Think he took shower and steamed the room clean.
Iorana Haraharaini
PostPosted: December 7th, 2010, 19:24
yeah....steam doesn't work.
PostPosted: December 7th, 2010, 19:29
State of the art clean room technology.
PostPosted: December 12th, 2010, 5:31
with shower in it . lol . :D
PostPosted: December 12th, 2010, 12:50
and you can check also the thermal stress...
PostPosted: December 14th, 2010, 14:28
the top right looks like a car stereo, you can listen to your favorite tracks while recovering data! Thats style!
Users browsing this forum: Google [Bot] and 66 guests
