 Post subject: Will a head swap acomplish anything?
PostPosted: December 11th, 2010, 10:41
If I can image a drive to 95% will a head swap accomplish anything, or is this a symptom of irreparable platter damage?
 Post subject: Re: Will a head swap acomplish anything?
PostPosted: December 11th, 2010, 13:44
Some more details would not hurt.
What are you using to image the drive. What for a drive is it. Where are the 5% of sectors that you can not image, at the beginning, middle or end of the drive? and what happens when you reach does bad sectors, can you see drive registers? any noise?
PostPosted: December 12th, 2010, 18:31
Quasimodo is right, you need to provide more details.
But I don't really think swapping heads will help you to get the 5%.
PostPosted: December 13th, 2010, 23:36
DI
80G Toshiba laptop
The MFT of course.
The usual busy regiters, noises.
The drive is no longer responsive, but I suspect a head swap would be a waist of a donor, since the heads successfully read most of the sectors.
Thanks.
PostPosted: December 14th, 2010, 5:45
Head swap won't help.
data recovery Poland
PostPosted: December 14th, 2010, 8:25
try uping the read retries and last resort read without ECC
Users browsing this forum: No registered users and 87 guests
