 Post subject: Seagate ST3250310AS 3.AAB
PostPosted: December 15th, 2010, 22:29
I have one Seagate hard disk, ST3250310AS 3.AAB. I believe, the head is having a problem because the hard disk does not detect by the computer and also heard the sounds of the hard disk spins fast and slow. So I get a donor hard disk which has same model, firmware, part number and country code.
However, after I replaced the head with the donor, the hard disk still not detect and still produce same spinning sounds. Then I thought it might because of the motor. After do platter swap, the hard disk is now detected by MHDD but when run the SCAN command, after a few sectors, there are many X's shown on terminal.
In your opinion, what is the real problem of this hard disk? I will be very grateful if you can give some advices or solutions to solve this problem.
Thank you for your help.
 Post subject: Re: Seagate ST3250310AS 3.AAB
PostPosted: December 16th, 2010, 4:00
BTW, have you tried to check terminal log before swapping heads?
PostPosted: December 17th, 2010, 2:58
Did you mean the log from MHDD?
PostPosted: December 17th, 2010, 4:14
No, I mean Seagate log.
PostPosted: February 14th, 2011, 1:02
I am not sure how to get the log from Seagate HDD. :(
-cypher.
Users browsing this forum: Google [Bot] and 62 guests
